Hi, a newb 35 adapter question, any help greatly appreciated
Hi everyone, I got some questions regarding THE adapter:
I would like to make one myself (duh). What I got is: -Sony vx2100e -Marumi macro +10 -empty rings (like 10 of them) -lenses (canon, nikon etc etc) -cd-motor and a frosted cd -about $300 questions: -how can I get the best quality+shallowest DOF using these parts? -or what could I buy to achieve the "best quality+shallowest DOF" result? -the frosted CD doesn't give me the quality I want, maybe I'm doing something wrong? (I'm using the mediachance.com DOF machine technique) would be better to not spend money at all, as I'm paying for my computer thanks everyone! |
I also started with the legendary mediachance guide. I've used that recipe with major modifications on my own machine. What i've learnt is that the mediachance recipe lacks certain things that cannot be overlooked.
First, you need a good SLR lens. Preferably a Nikon, Canon or similar. Get one with a low f-value, 1.4 or 1.2 is preferred. The lower value, the lower depth-of-field and the brighter image. 1.2 might be overkill though (and they're very expensive), some say you get a too short DOF (a couple of inches in focus). I started with a cheap brand 1.9 lens and got horrible vignetting (dark edges). Buying me a F1.4 Canon certainly solved some of the issues. Secondly, you'll probably need a condenser lens to avoid vignetting. Even though I'm using a Canon F1.4 I still get vignetting. I've solved this with a condenser and the image is now fine. I would advise you to build quick and dirty prototypes of the machine, testing different approaches. I built my first machines with milk cartons and wood from a messageboard. To get even more familiar you can also start by testing the latest approach for STATIC DOF-machines - plastic bags. Get a plastic bag that is diffusive (called "freeze-bags" in Sweden), stretch it and point the lens on it. Maybe you won't need a spinning ground glass. But as I stated earlier, my first advise is to get a lens and do some experimenting. |
Thanks alot, guys
I have a canon 1.8 lens, going to get a 1.4 a bit later Now: what exactly IS a condenser lens? and: what does the bag look like? a screenshot maybe? and: what about quality? thanks |
A roll of "fryspåsar" (freeze bags) is a the upper right of the photo below. http://c4hvbat.origo.net/images/knltin0019.jpg |
Haha...true. But I was just saying buy the fastest lens available in your budget.
And, don't kill me, but I did manage to swipe a Canon FD 1.2 off ebay for $70. You just gotta keep an eye out for good deals :) |
I got my Canon FD 1.4 for 10 Euros (~$10) :) off eBay Germany.
With a little bit of luck and patience, you might find a bargain. |
and what about quality? thanks |
A condenser lens is a general term for a couple different varieties of lenses, the chief purpose of which is to gather and focus light. (It "condenses" it.) Most people around here use PCX (technically known as plano-convex) lenses. They are curved outward on one side and flat on the other. In general, shorter focal lengths are better because they focus the light more.
As for quality, that's going to change with practically every piece you put in your adapter. Condenser, ground glass, 35mm lens and macro are all going to affect what kind of picture you get in the end. Like Carl mentioned, the rage around here right now is the use of alternate-material diffusers (instead of traditional ground glasses) like plastic bags. Some people have gotten very good results with these, and others not so good. If you decide to go with a ground glass instead, the higher the grind (larger grit number), the less grain you're going to see in the final picture. As for myself, I'm building a static adapter rather than a moving one. I'm shooting on HD so it's yet to be determined if I'm going to be able to get rid of enough of the grain in a static design, but some people have been getting extremely good results on DV with static designs, and in general they're cheaper and easier to build, so if you're not fixed on a moving design, you might want to check out the "Working DIY Adapter" thread, which describes Jimmy Hedberg's take on Richard Mellor's design and is relatively easy to understand. Hope this helps! |
Thanks Joel,
I don't care about the GG (static/moving), I just need good results. Now, where could I get a condenser lens? What does it look like? I mean, do I take it out of an old camera lens, or what? |
you could try to build a gg/condenser in one piece.
find a lense of about 55-60mm of diameter. one side of this lense must be flat , the other one is convex (slightly). the difference of thickness between the center of the lens and its borders sould be no more than few milimeters (about 5) ideally the lens is very thin (border are 2 or 3 milimeters thick). put some wax (or contact glue or scotch tape) on the convex side to protect it. then you pass the flat side on different sand paper. starting with 600. Always move the lense on the paper fixed to a really flat surface (marble or thick glass) if your lens is really flat, it will become scratched on all surface immediately. if not (most probable), it will scratch only the center of the lens. So go back to 200 sand paper and make it flat. (you can even use electrical tools for this at slow speed) when it is really flat, go back to 600 then 800 then 1200 sand paper and finish with 1500 aluminim oxid.(glass to glass) When using sand paper, alway us a lot of water, to avoid deep scratch. use special wet sand paper. this way you will get (with a lot of effort) the best GG/condenser you could ever dream. (but is not ok for HDV). This can be managed over a quiet week-end (no wife, no children). |
Thanks Giroud,
where could I find such a lens? a magnifying glass? or dismantle some photo lens? I don't care about HDV right now, so I hope this will do. |
It looks like most people on here get their lenses from Optosigma, which cheaper and easier than trying to dismantle an SLR lens.
Ivan, I'll sell you mine for $25, shipping included. I used it for my adapter and it worked great. It's an Optosigma FL70mm plano-convex lens, then same used in Richard Mellor's design. The size is 52mm.
how to tell if your GG is ok :
the first test you can do is to check for the lens, if there is any distorsion. draw a line on a paper. slide the gg-lens on the paper and look a the line. It should stay straight as much as possible when it reach the edge of the lens. if not, you will need to add a lens to correct that later. check transparency: You should not be able to see anything trough the gg, except a diffuse white light . apply the gg to a newspaper. you should see the text as sharp and clear as if the gg would be transparent. lift up a bit the gg from the paper. the text should disappear almost immediately and should not be visible with about half an inch (12 mm) of distance. if you get this, you will probably not have to worry about hotspot. most people have problems with gg because they are too transparent (you can see the back of the lens trough the gg). This could happen if you insist too much on last polishing with 1550 Alu. oxide. So if you get a perfect surface (no scratch) after a while. stop and make a test, insisting to much just create new scratches and does not improve really. how to prevent scratches: use a piece of glass as support (20x20cm is ok). put you aluminum oxid into a small recipient with cover (i use baby food pot). put 2 or 3 coffee spoon into the pot, fill with mineral water up to half. I cannot recommend regular water, since it can contain sand. shake a bit (about 30 sec). open the pot, use a syringe to get some. just take from about 10mm deep from the surface (some impurities are floating, other goes to the bottom of the pot). for the begining, you can use it just after shaing the mix, for the end of the work, you can wait between 10 sec to 1 min to make sure you got only the finest aluminium oxide. the mix looks like milk ot white water. work with it with a mix of small circular and linear motion. rotate the lens under your finger, so pressure does not apply alway the same place. The water will evaporate and the mix will dry while you work. add more from the syringe to keep it wet, but not too much liquid. if you feel/hear some scratch (like sand rolling under the teeth), stop, wash everything with mineral water and start again. You probable have a grain in the mix and scratched your lens. If you get a can of compressed air (the one used to clean lens), use it to dry the lens sometime and check how it goes. |
Ben: what are you going to sell exactly? the PCX lens? is it ground already? will it fit my design? the bad thing is, my marumi macro +10 doesn't have threads on the outside, does it mean i will have to use glue? Thanks Giroud |
Ivan, I'm selling 50mm 70fl:part number 011-2870 from Optosigma: http://www.optosigma.com/miva/mercha...herical+Lenses
Unground, unthreaded. A cool tip I learned: Buy a cheap UV filter, unscrew the unside to take out the filter, and what you're left with is a filter casing that you can insert any optical element into with the same diameter to make threaded. For instance, if you wanted to turn this PCX that I'm selling into a mountable 52mm optical element, just replace a 52mm UV filter glass with the PCX lens. I could do it for you before I shipped it to you if you wanted me to. You can do the same with your macro +10. I don't know if it will fit your design or not yet--give me some more details. Are you using a threaded design, or are you gluing everything together? What size are your empty filter rings? What size is your macro? The best bet, I believe, would be to buy a project box to house the spinning CD in, and then glue a filter ring to one side so you can attach your macro, condenser, camera, etc. And then attach an SLR mount to the other side. |
| All times are GMT -6. The time now is 11:22 AM. |
