-   Alternative Imaging Methods (https://www.dvinfo.net/forum/alternative-imaging-methods/)
-   -   Anyone know who's set up this is? (https://www.dvinfo.net/forum/alternative-imaging-methods/58874-anyone-know-whos-set-up.html)
Greg Bates January 22nd, 2006 12:22 PM
http://static.flickr.com/37/87599587_d298149141_o.jpg
Keith Kline January 22nd, 2006 01:16 PM
No Clue
But I'd be curious to know who's as well. I know I tried something similar using the EF adapter and 24mm lens and even with the lens that wide I still had to have the ground glass alot farther from the lens to get the framing right.
Jim Lafferty January 22nd, 2006 01:31 PM
What's the advantage over just going straight from the M2 to the XL1?
Bill Porter January 22nd, 2006 01:36 PM
Yes I do. It's Patrick Pai's.
http://www.dvinfo.net/conf/showthread.php?t=57789
I simply searched for it. What a great guy. Modest, too.
Greg Bates January 22nd, 2006 01:48 PM
Thanks for the link.
Keith Kline January 22nd, 2006 02:25 PM
Not really too much other than it brings the length of the unit down.
Greg Bates January 22nd, 2006 03:27 PM
Less light loss as is proven with the mini35 on the xl vs. the DVX.
Keith Kline January 22nd, 2006 03:58 PM
Yeah but Jim was asking about the difference between using a Micro 35 mounted to the stock XL lens versus an XL using a an EOS to XL adapter then into the Micro 35. Basically using the EOS to XL adapter and lens as a relay lens similar to what is used with the Mini35.
Greg Bates January 22nd, 2006 04:23 PM
I think we are saying almost the same thing, at least a combining the two. Less light loss and less weight/length, and that's if it works. I was reading the thread but there is no mention of it worked, no screen grabs etc. 20mm is not that far off of the 24mm you used either. Do you have an M2?
Bill Porter January 22nd, 2006 04:36 PM
No need to thank me. I already said I was a great guy! LOL
