-   Alternative Imaging Methods (https://www.dvinfo.net/forum/alternative-imaging-methods/)
-   -   Letus35 Flipped vignetting (https://www.dvinfo.net/forum/alternative-imaging-methods/58576-letus35-flipped-vignetting.html)
Sean Michael January 18th, 2006 11:34 AM
Is anyone else getting vignetting with the Letus35 flipped? Also, it seems I have to zoom in on the gg almost all of the way to get rid of the black edges... Is anyone else getting this? What is the standard setting for zoom on the dvx100a for the this adapter... Help please
Also, my thread to the dvx doesn't tighten all of the way. Meaning, I have to leave it loose in order to frame it up correctly(parallel to the ground). Is that normal?
Quyen Le January 18th, 2006 12:06 PM
Tight it in all the way then pull the adapter off the ring so the ring stay on camera. Have your LCD on and insert it back in with right orientation. Normal zoom level for DVX100 is around z90, not sure for DVX100a. Thanks.
Quyen
Greg Bates January 18th, 2006 12:58 PM
I used a screw driver to separate the adapter from the 72mm collar (GENTLY). Screwed the collar on and put the adapter back on.
Leo Mandy January 18th, 2006 04:56 PM
I got it with the panasonic 852, but I put a condenser right in front of my lens, so it is gone now.
