Nice find Dennis! It would be the perfect screen if it had S-video input.
Good job, Ben. Keep it up!
Ben, an alternative is to just use an svideo to composite adapter...like this one: http://www.showmecables.com/productD...idproduct=2360
My cam has both, so I use the composite for my external display. Not ideal, but it works OK. |
Actually Dennis I have one right here in my desk drawer. The quality blows chunks though.
Bill, the screen is in fact rated at 8 watts. With the JVC batteries I have, the $20 cheapos and the big fat one on the way I'm no longer worried about battery power, but for others looking into this, it's good to know. :) I wish I could tell you the amp-hour rating of the battery but it isn't here yet and I lost the link. I'm sure its >5400mAh though. |
the liliput i got (under 300$ as well) is 800x600, so probably better for PAL.
The only thing i dislike for mine is the poor connector (all in one tiny flat connector). I prefer simple BNC or cinch. It connects too on a PC, so can be usefull for teleprompter uses. For the batteries, i use some li-ion pack (huge ratio energy/volume/weigth) they are cheap and can power my 7" LCD (noname brand) for at least 2 hours. (the 4000mA version, the LCD takes about 1500mA/hours) . You can purchase the pack+charger for very cheap (about 80$) at www.batteryspace.com They got 6000mA packs too (4 hours). the only drawback is to find a voltage stabilizer to reduce the 14.4 (sometime labelled 18V) to 12V. The solution is to purchase a 10$ kit (poststamp sized print with a low drop regulator). I use them a lot. the main component is a low drop voltage regulator like the LT 1085-12CT 12V 3A. If you got 2 left hand or are too lazy you can use this http://www.batteryspace.com/index.as...ROD&ProdID=919, looks better and ready for use. |
Ben, how would you characterize the difference in composite vs s-video on your 7" LCD? I've been looking for one of these for awhile in the 800x480 flavour, however I hadn't considered how noticeable the connect type would be on a 7" screen. Perhaps I should be considering s-video...
It's a stinker that portable dvd players in this size don't use the better screen. My screen isn't that great, but I sure like having the onboard lithium battery. |
Just wondering! Would just about any 12v LCD Monitor work? Like the ones in vans and other suv's??? If so, you could go to just about any wrecking yard and pick one up and with a little engineering you could put one together for pretty cheep...
John, I'm guessing that would work, but I really don't think the resolution is very good on those things either. I mean, c'mon, that's stooping pretty low in the name of saving money...lol. I doubt the car uses s-video too. That'd be a pain to wire.
Saw your question about s-video vs. composite quality. The composite signal is much blurrier and less detailed, which is exactly what we don't want if we're trying to focus something. |
Ben, XM2 owner here in PAL-land:
Q1: How/which socket are you getting the video to the monitor? On a 4:3 monitor I use the BNC out from the MA300 adaptor. I couldn't see the "lead" connections in your photos. Q2: How do you achieve the 16:9? Is that just the setup in the XM2 menu and that just zaps to the 16:9 monitor? Q3: How is all that weight on that single foot? Would scare the pants of me! TIA Grazie |
Edit - double post . . .
Two things I want to mention:
I am concerned about that much weight on a hotshoe, so I am building a monitor support into my rod support system. Batteries are often rated on a slow-draw test. They can not put out their full rating for a whole hour. The total quantity of energy available is the same as their rating for one hour, but if they are drained that fast the capacity goes down. For example, a 1 AmpHour (1000mAH) 12V battery (actually more like 13V) would put out 13W for less than an hour if drained that fast. It WILL put out 1 watt for 13 hours. An 8W monitor will run more than four time as long on a 4AH battery than a 1AH battery. Don't forget that Amps = Volts x Watts, so a 7.2V 5400mAH battery has less juice than a 12V 5400mAH model. What this all means is that you will get better battery life and longevity if you get a bigger battery. I got a couple of 12V 7AH batteries cheaply so that is what I am going to use. They should each last all day with my <10W monitor. Unfortunately, they are a bit heavy, so a 5AH battery would probably be best unless you get a battery belt. |
Grazie |
Oh, by the way, I received an email back from the guys who sold me the screen: Quote:
Thanks Ben.
I didn't know about the metal construction under the hat of the XM2 - thanks. Concerning the " . as low as 7.2" what would it do to the battery? Loading a battery at that low output? I was under the impression that it isn't a good thing to load a depleted battery? (Ben: Sorry, maybe you missed my question on the Letus . . But what is that dreamy ZOOM lens in your movie of your Letus support?) Grazie |
Graham, I'm not sure I understand about loading a depleted battery, I'm just saying that any 12v battery that loses voltage as it is used isn't a problem since the LCD screen seems to function on a voltage range from 7 to 12, which is a pretty big range. So voltage loss because of battery drain shouldn't be considered a problem.
Graham I'm sorry I forgot to answer your previous question. I'm deciding to keep it a secret :). Haha. Just kidding. I'm at school now, so I'll have to look it up for you when I get home. |
