-   Alternative Imaging Methods (https://www.dvinfo.net/forum/alternative-imaging-methods/)
-   -   Letus35a DVX100a footage (https://www.dvinfo.net/forum/alternative-imaging-methods/53329-letus35a-dvx100a-footage.html)
Lloyd Choi October 25th, 2005 12:30 PM
30 second clip(s) of footage I'm not using for a short film i'm doing.
Shot on a DVX100a, 24p. Only lighting was natural light, bounced with a reflector (only applies to the third clip)
No colour correction except the very last clip, I bumped contrast and saturation a tad.
You'll notice on the 3rd clip (guy drinking) that there is something on the right hand side... due to the adapter not correctly aligned. Can easily be fixed in post by enlarging the image slightly, but I chose not to use it.
Enjoy.
http://s13.yousendit.com/d.aspx?id=3...6Y0M6V0CPKRF43
Edit: also to note: compression is sorenson 3, 80% quality. 17mb file. I suck at compression
Steev Dinkins October 25th, 2005 02:46 PM
Looks great, very clean. I'm looking forward to the Letus being available for the HVX200.
Anhar Miah October 25th, 2005 05:39 PM
May I ask what the difference is between the letus35 and letus35a ?
Anhar
Rafael Lopes October 26th, 2005 03:41 AM
The download always stops in the middle. I tried different browsers, different connection speeds (mine is a 6 mb broadband), different pcs, but it always stops around 10 or 12 mb. Don't know what's going on. I'd really like to see the footage.
Jay Rodriguez October 26th, 2005 05:02 AM
thanks for the link
Lloyd Choi October 26th, 2005 10:14 PM
Here is some more stuff...
I am currently fooling around with compression. This is H.264 quicktime
I had to increase contrast because when it exported, the image became washed out big time.
http://s22.yousendit.com/d.aspx?id=0...V1J03PXLXWOILB
Emiel Labree October 27th, 2005 04:50 PM
Perhaps due to compression, but the video looks a little out of focus and unsharp compared to some other examples that were made with the DVX100.
John C Cha October 27th, 2005 11:18 PM
The Letus 35 looks amazing on the DVX100a
Those are some pretty ordinary scenes, but the elongation effect and depth of field transform them. I have a question, Lloyd. It looks like you have a really high shutter angle in the first shots where you are doing handheld, walking backwards. Is the lighting really hot, or you just wanted to get that sharp jittery look? What's your f-stop there?
Lloyd Choi October 27th, 2005 11:27 PM
I was doing handheld, trying to make it smooth haha, but it's hard walking backwards. I hit a pole too, which was fun.
this is part of a short film I'm making, and I wanted this segment to be all handheld to give that sense of realism.
I used a 50mm Canon FD 1.8 lens. the Fstop on the DVX was f14. It was a relatively cloudy day, and I boosted the orange glow in-camera.
I believe I shot at a 1/120 shutter speed, don't quote me on that though.
Lloyd Choi October 28th, 2005 12:26 AM
Here's some more footage...
no CC whatsoever.. you'll notice that the image became washed out due to H264 compression: no idea why it does that.
http://s30.yousendit.com/d.aspx?id=0...O2ORLHADAGJUI5
7mb
Bill Porter October 28th, 2005 11:49 AM
Why did you have the DVX stopped down so far rather than running it wide open or close to wide open?
Lloyd Choi October 28th, 2005 12:47 PM
when the DVX was set to F2.4 or anything around that, everything was blown out.
The aperture doesn't work on my 50mm lens, so it's always at f1.8. I just adjust the iris on the DVX
Chad Schultz October 28th, 2005 02:05 PM
Lloyd,
Your footage looks nice. If you have a minute of free time could you post a pic of the insides of your Letus35a for me to compare mine to? I'm not sure which version I have and if I should order the new achromat or not.
Lloyd Choi October 28th, 2005 09:37 PM
Chad,
Anything for a fellow Canadian ;)
I'll try and get a hand on a digital camera to take some pics.
Jay Rodriguez October 29th, 2005 01:54 PM
Mine is already shipped, I can't wait to get it....
Ben Winter October 30th, 2005 10:09 AM
does ANYONE know the difference between the 35 and the 35A ?!!!!
Quyen Le October 30th, 2005 10:31 AM
Yes, I do :D
There are some updates have been done to the Letus35A.
- Resistor removed for faster spinning
- Better achromat
- We lately make the GG bigger a little bit for DVX100 version since it has problem focusing when it's not perfectly aligned. So if you place an order and have DVX100(a), please say so, this feature is free and if you have other camera and want bigger GG as well, please note with your paypal order.
Thanks.
Quyen
Robert Mann Z. October 30th, 2005 01:50 PM
so does the adapter fit directly onto the dvx or do you need a step up ring?
Emiel Labree October 30th, 2005 01:53 PM
You'll need a step down ring. The Letus35 has a 58mm filter thread, while the DVX has a 72mm filter thread.
Edit: had the dvx filter thread wrong.
Lloyd Choi October 30th, 2005 02:39 PM
DVX is 72mm ;)
Emiel Labree October 30th, 2005 02:43 PM
Originally Posted by Lloyd Choi
DVX is 72mm ;)
You're correct. My bad.
Aaron McMath October 30th, 2005 03:52 PM
Quyen
Is there any possible drawback to having the larger GG? Otherwise I would think it should be standard in case we end up using a dvx or another camera that turns out to have a similar problem.
