-   Alternative Imaging Methods (https://www.dvinfo.net/forum/alternative-imaging-methods/)
-   -   New method for spinning real Ground Glass (https://www.dvinfo.net/forum/alternative-imaging-methods/50507-new-method-spinning-real-ground-glass.html)
Craig Bellaire September 19th, 2005 12:57 PM
Glass to Plastic
Just wondered how you attached the Glass to the motor. In the Guide you say to use 3 screws... BUT in the picture you seem to have a different attachment Method...
Wayne Kinney September 19th, 2005 12:59 PM
Craig.
Always 3 screws, but with thick rubber washers so the screws will not 'crush' the glass.
Wayne.
Michael Maier September 19th, 2005 06:03 PM
What's gyroeffect?
Wayne Kinney September 19th, 2005 06:08 PM
Now this is a hard one to explain:D
Its a force that acts on a spinning object. With my spinning glass, there is a resistance to any rotational movement around its own axis, but only around 2 axis, the other two axis other then the one the glass is spinning around
Im not very clear about it, but see here for a more detailed explaination.
http://www.sheldonbrown.com/brandt/gyro.html
Or if your a mathmatician, go here;)
http://print.google.co.uk/print?id=5...kuPE0inm4xA-NY
Wayne.
Michael Maier September 19th, 2005 06:12 PM
Ok, but How does it affect performance or use in the real world?
Michael Maier September 19th, 2005 06:20 PM
How loud is the adapter by the way?
Wayne Kinney September 19th, 2005 06:21 PM
OK,
Basically there is a theoretical resistance against panning and tilting movement. Have I noticed any resistance when using the unit? NONE AT ALL.
My only real concern when first coming up with the design a while back was if the gyroeffect was going to be so strong as to shatter the glass. I now know that this is not the case with my design.
I think the main difference was the macro with the tests with the dvx100? Not sure.
I have a potential buyer wanted to use onto a dvx100a. He would post results with my unit. I dont have access to that kind of equipment, sorry.
Wayne.
Michael Maier September 19th, 2005 06:24 PM
Thanks.
Also, I wonder if the results wouldn't be worse with a higher resolution camera like a DVX100 and XL2. I think that happened to the Letus35 is another thread. Somebody said it looked better with a cheaper camera than with a DVX100. Do you have the possibility of testing it with a better camera?
