Sampling grain
Although I have a great working rotating ground glass, I came up with an idea which I'd like to test.
Maybe I don't understand grain enough or other people have tried this... How about sampling the grain of an ordinary static GG, by shooting a white board or something, so you have only the grain strukture of the GG. If you put that sample in negative on top of other footage (in post software) and use it to lighten/darken, ie reduce the grain, maybe even compensate a hotspot. Any thoughts? Maybe grain deforms the image too, so it wouldn't work. |
I don't think you would have to even shoot the grain on a white board background, I know that Vegas has a Grain FX installed with the NLE that simulates grain for 8, 16 and 35mm colour and B&W film. IS that what you are talking about?
Very interesting idea... I already though about something like this, especially for scratches removing. As screen is moving, scratches stays static. So its not hard to find them. After you have their positions, you can replace this pixels from pixels aroud by moving. Some very clever logo removers work this way, so you will do not believe there was logo before, if you have a enough movement to determine area under logo. I do not know if somenthing like this exists...
This is problem with sampling grain:
The grainy screen consists of tiny dark spots of varying darkness. You would have to make screen as dark as darkest spots, to make it uniform. You'd lose too much dynamic range / lattitude, low light capability. The moving screen will average dark and bright spots. It is lot more efficient, especially because there is low percewntage of dark spots. |
I do not know... I think that if you take just mask of the scene (I mean the grain as mask), you are able to get it out. You can do it in several ways. 1) compute dark spots to be brighter, 2) compute bright spots to be darker or 3) make average between. The different is not so big, so I guess u do not lose to much dynamic.
I think Daves got my point, but maybe I was not very clear.
This is what I mean: Make a 35mm adapter with a static GG. Sample that static grain. Put that grain footage (just one frame, because the grain is static) in a post prog. in negative on top of other footage and mess around with opacity and layer type until you get the grain to disappear. So I'm not talking about moving GG or sampling the grain to put into other footage. Like Daves said, it would also reduce scratches. If it works. |
Hey Oscar :)
I started a similar thread a while back. Not sure where it is now. Anyway, it was tested and seemed to work out ok. Some people had trouble reproducing good results though. You need to make sure that the adapter is always oriented perfectly or when you try to remove the grain you will just add more. |
Aaron, that's what I figured. The adapter has to stay on the camcorder and don't move at all or the grain will be displaced and you have to start again.
I'll test this anyhow some time next week. I'll try to find your thread. |
