-   Alternative Imaging Methods (https://www.dvinfo.net/forum/alternative-imaging-methods/)
-   -   how about a directors finder (https://www.dvinfo.net/forum/alternative-imaging-methods/39124-how-about-directors-finder.html)
Justin Neri February 8th, 2005 11:13 PM
how about using a directors finder as an adapter? you know the things the director uses to see how the shot is gonna look thru the film lens.
can that work?
Rob Lohman February 9th, 2005 07:14 AM
Welcome aboard DVInfo.net Justin! I assume you mean to attach
a 35mm adapter to your camera? It might work but I doubt it
will retain the depth-of-field, which is what everybody is after...
Justin Neri February 9th, 2005 07:18 AM
http://shop.store.yahoo.com/cinemasu...ekistdivi.html
but they have a ground glass in them and you will see the depth if you look into it. is the glass to far away for the camera lens or something.
thanks for the welcome. ive been following these boards for years.. the info is so great. there is almost too much to handle.
Rob Lohman February 9th, 2005 07:29 AM
Do you know there is a groundglass in there? because I can't
make that out from that page. I'm not sure if you would need a
ground glass with a human eye, I can imagine if you space the
eye at the correct distance from the lens end it may be able to
see it correctly, but what do I know <g>
It's certainly an interesting idea.... I hope someone who has
more experience with these kind of things can chime in...
p.s. if there is a ground glass in there it might be too coarse as
well etc.
Justin Neri February 9th, 2005 07:41 AM
some of the designs if not all seem to have a ground glass.
another question, how come i can not see any grain when looking into a 35mm still camera?
i just tore apart my old 35mm, man what fun. the pentaprism is awesome. too bad its not big enough for an adapter application.
Charles Papert February 9th, 2005 10:58 AM
The Kish in that link does not have a ground glass, and it also has no perceivable depth of field effect. Kish does manufacture a version with PL mount that will give the look you are going after, but the ground glass is indeed fixed and somewhat coarse. P+S Technik makes a version of this that includes a small DV camcorder to record rehearsals. It's pretty easy to see that once they had developed this technology, how they arrived at the idea for the original Mini35 that spurred all this.
Oscar Spierenburg February 10th, 2005 05:40 PM
I think this is an expensive solution to something that could be made for almost nothing.
However, something I mentioned before, although no one responded, is to use a sort of director’s finder as a separate viewfinder to solve the mirrored image you'll get with the 35mm adapters. You'll also save the batteries from LCD use.
Than remains the problem of focusing, but maybe the best way to focus is the way they did (and do) in the film industry, just measure the distance from the lens to the subject with a tape measure and set the lens.
Does anyone know a way to make a directors finder, maybe from old photo cameras?
Leo Mandy February 10th, 2005 05:45 PM
Good idea, there has to be old parts that would work as a make-shift Director's finder - an old 8mm film camera?
Filip Kovcin February 10th, 2005 06:25 PM
i cannot find better image, but this type has GG and therefore you celarly see DOF.
http://www.jrsfilm.com/Kim%20with%20...vid%20full.jpg
will try to search for closeup. i know that panavision usually has this with it's own equipment.
filip
Filip Kovcin February 10th, 2005 06:28 PM
i'm not sure about this one...
http://us.ent4.yimg.com/movies.yahoo...viewfinder.jpg
filip
Charles Papert February 10th, 2005 06:42 PM
Filip, that first one is indeed a Panavision finder, there are a few versions available but generally they are made by 3rd parties such as Kish (don't remember who makes that particular one). The other one you linked I have never seen before, but I like the size!
Filip Kovcin February 10th, 2005 07:00 PM
<<<-- Originally posted by Charles Papert :The other one you linked I have never seen before, but I like the size! -->>>
Charles,
but the size is what make me suspicious. i'm not sure there is place/space for GG...
btw. maybe you can recognize - is this HD prime (zeiss)?
looks like.
filip
Charles Papert February 10th, 2005 07:45 PM
That looks to me like a Zeiss/Arri Ultra prime--i.e, 35mm format.
Filip Kovcin February 10th, 2005 07:56 PM
thanks Charles,
you are probably right :)
