Is there are list of 35mm adapter websites?
Hi all. I've been away from the forums for a while, and was wondering if anyone has put up a website, or even a thread here that soley has links to all the projects people are doing with instructions, pics etc?
There is such a HUGE amount of information about this, and a lot goes back and forth, get's altered, is discovered to be not as good as another method etc. Maybe this thread could be that if there isn't one already? Aaron |
Hi Aaron,
I'm working on a section of DV Info Net which will cover a list of links as well as a preliminary F.A.Q. which Nicholi Brossia has contributed. So, I'm also very interested in a comprehensive list of links which we can post from the main site here. Also, related topic, I've been thinking about creating sub-forums within this board but could use some input as to what the categories should be. Thanks, |
Chris, I hope you do put this info up in the organized fashion you imagine. It'll be an improvement over the current ad-hoc welter of threads.
I'm all for it -- I just need some direction!
However you guys want it all organized; it's your board. |
I've lost this link but found it again, maybe it's a site from someone on the board:
http://www.mediachance.com/dvdlab/dof/index.htm |
Just try
http://www.35mm-adapter.de/index.php...2035mm-Adapter It's in German, but if you send a request to Blindcat, I'm sure, he will create a english version too. Some kind of a summery for all available 35mm-adapter versions and some kind of compendium for the different parts (macro/diopter, gg/glasscreen, ...) with all advantages and problems would be just great! Cheers, martin |
Great post! Thanks Steev!
It must have cost you hours to get the Beattie screen round. If you want to go on 35mm Adapter Mission. Pt. 5/6 I would suggest a glasscreen. You can even order a round one with the diameter you need. I don't know exactly how much the shipping to the US will be, but the screen itself will cost about 60 $. Here's the link: www.glasscreen.com Greets, martin |
| All times are GMT -6. The time now is 03:37 PM. |
