XL1s Audio - output headphones
Any suggestion to increase the output gain form the XL-1s headphone jack? I have it at max and the volume is not what I would like to hear.
Regards Steve |
If you're using an xlr mic you may need to adjust the levels on camera... or set it to audio. I've actually had to replace AA batteries in my shotguns... I also have a mono to stereo adapter for when shooting with a mono mic on one channel...
I also since not a long time have an XL1s, and I noticed it first too, the headphones were so quiet I thought it was broken! But now, at the maximum I hear it, but it is indeed quiet.
I can't help you though, sorry. Good luck! |
On the DVX we heard many complaints about low headphone volume; I'm assuming it's a similar issue as to the XL1. With the DVX, the headphone jack was mated (impedance-wise) to professional headphones, such as the Sony MDR-7506. When used with consumer headphones, the volume was very low, but when used with the MDR-7506's there was plenty of volume.
So it may be a simple ohm impedance issue, which would be solved by getting a more-matched set of headphones. Or, you could get a headphone amplifier. I believe people have used the Boostaroo with success: www.boostaroo.com |
Is a sennheiser good? I already have one, and I use it now on the XL1S, I just wanted to check. I still find it to be relatively quiet. It's a Sennheiser HD-570, I bought it to use with my stage piano, but when I got my XL1S I decided to use it for it.
