-   Alternative Imaging Methods (https://www.dvinfo.net/forum/alternative-imaging-methods/)
-   -   question about mini35 (https://www.dvinfo.net/forum/alternative-imaging-methods/36512-question-about-mini35.html)
Arthur To December 17th, 2004 03:56 AM
hi is there any magnification when using the mini35... if not... why not?
i recently bought a lens (nikon AF) just to test it. i took of the standard xl1s lens and held it in front, if i hold it properly (very close) i can get a clear focus.... but the magnification looks quite immense. so when it is secured (like with a mini35), why is there no magnification?
thanks- (btw, please explain in clear terms, im a tad slow on these things)
thanks-
arthur
Josh Brusin December 17th, 2004 11:05 PM
you're not shooting through the lens... with the mini35 you're recording off an image relayed through the lens to the glass... a telecine basically.... no magnification.
Arthur To December 18th, 2004 03:51 AM
ooh
ooooh thanks!!
i held up a ground glass at the lens and WOW omg i get what you mean by projected image, its the most agamzing thing ever.
i am one mere step away. how do you get the lens-less xl1s to focus on the ground glass?
so ive got my xl1s without any lens on.... i hold that ground glass as close to it as possible and start moving further and further away, no luck.... how does the mini35 do it? what can i do to get it to focus on the ground glass? (what do i add in between?)
thanks a bunch
-arthur
Barry Green December 18th, 2004 02:22 PM
It isn't lens-less. The mini35 adapter includes a lens, a special-purpose relay lens that focuses the ground-glass image onto the CCD's.
Arthur To December 19th, 2004 04:24 PM
ok
ok so how about me? (without the mini 35), what can i do/use to help my lensless xl1s focus on the gg?
-arthur
Barry Green December 19th, 2004 05:54 PM
You would have to do the same thing. You would have to use some sort of relay lens.
