-   Alternative Imaging Methods (https://www.dvinfo.net/forum/alternative-imaging-methods/)
-   -   an easier solution? (https://www.dvinfo.net/forum/alternative-imaging-methods/35542-easier-solution.html)
Arthur To November 27th, 2004 02:32 AM
an easier solution?
hi, i saw a guy with a homemade mini35, and he put a canon SLR lens on it (a relatively in expensive one). he turned on the motor and it was AMAZING!.
but what if i bought that lens, and a canon XL1s EF adapter and put THAT on my XL...... would i get the same effect? why or why not?-- assuming i'd also get a wide angle lens to kill that disgusting 7.2x magnification. would i be looking at the same DEPTH OF FIELD?
thx
-arthur
Elmar Tewes November 27th, 2004 09:05 AM
you cant kill that 7.2x magnification by using a wide angle lense. the focal length is still 7.2x, just the new focal length will be lower cause you used a lense with a low focal length (100mm - 720mm, 15mm - 108mm).
but that construction doesn't change the depth of field. that home made mini35 uses a special construction to imitate the mini35, but its still a optical system (with old photo cameras or rotating fake cd's ect), the ef adapter is a mechanical adapter. i suppose it was invented to use the xl-1 for filming wildlife or reasons where a extreme high focal length is needed
Cosmin Rotaru November 30th, 2004 07:10 AM
DOF depends on focal lens. The loger the focal lens, the shorter the DOF.
So, using a very wide lens (to "kill" the 7.2X magnification) means you get a very long DOF. Actualy, the lens you're already using on your XL1S is a very wide lens. 7.2X wider then a "normal" (like the canon SLR you talked about) lens. That's why you get that long DOF.
