-   Alternative Imaging Methods (https://www.dvinfo.net/forum/alternative-imaging-methods/)
-   -   35 mm Adapter without GG (https://www.dvinfo.net/forum/alternative-imaging-methods/27474-35-mm-adapter-without-gg.html)
Mike Metken June 12th, 2004 04:01 PM
Here's an idea that may possibly work. You project the image on a perfectly white surface.Then you would be aiming the camera at the surface from the same side. The angle between the 35 mm lens and the camera lens would be minimal. You would then use special optics to take care of the image distortion and to focus properly at that angle. You could install the special optics at both sides, for the image to project undistorted and in focus and for the camera to see the image undistorted and in focus. I don't know anything about optics but Edmunds or someone could suggest what to do. Probably a simple single lens that would be turned slightly. No ground glass, no moving parts. But maybe too complicated.
Mike
Valeriu Campan June 12th, 2004 06:37 PM
Re: 35 mm Adapter without GG
<<<-But maybe too complicated.
Couldn't agree more
Frank Ladner June 12th, 2004 10:09 PM
Mike: That is a good idea. Some of us have talked about something similar to what you describe, but I think it would be pretty complicated. However, don't let that keep you from trying it out!
,Frank
Brett Erskine June 12th, 2004 11:35 PM
Heres one simple way to do it
Last time this was talked about I mentioned one of my early designs. It works on the same basic idea of video taping the 35mm image after it is projected on a solid white surface. Basically what your talking about is a front projected image versus a rear projected image which is the idea behind the designs using ground glass instead. So if you want to try doing a front projected design without special corrective optics you can do it with one 2-way mirror and one normal mirror. Thats it. Simple.
Heres how it works. The image from the 35mm lens is projected on a flat white surface but not before passing straight thru a 2-way mirror. The 2-way mirror is tilted forward at a 45 degree angle. This mirror allows the video camera to view the white surface at the EXACT same angle as the 35mm lens.
The second mirror (which is just a regular mirror) is placed directly below the 2-way mirror and at a rear tilted 45 degree angle. With this mirror your able to have the video camera mounted the way you want it to - in the same direction as the 35mm lens. Throw it in a housing and your done.
I know its hard to picture a design from just text so let me know if this doesnt make sense. Its a good design without any grain. It has only one draw back...light loss.
-Brett Erskine
www.CinematographerReels.com
John Cabrera June 13th, 2004 12:21 AM
Light loss
How much more light loss than the light loss we get with the current GG designs? I don't think I've ever really seen a 2-way mirror... unless you count oakly sunglasses... will the mirror coating cause the amount of light loss one would see with mirrored sunglasses?
John
Mike Metken June 13th, 2004 02:45 AM
Brett,
I thought about the 2-way mirror too, but then I figured too much light loss. I don't know anything about 2-way mirrors and on what principle they work. Does anyone know?
Mike
Brett Erskine June 13th, 2004 02:14 PM
Oh yeah I forgot to mention that my design also flips the image up right in the process BUT you still have to correct for left and right.
You can easily do this with most video cameras. Just look for some type of feature in the menu that flip the image left to right. Usually its called "mirror".
Another thing for thoughs that want to make one and make one right - buy optical grade mirrors.
The who, what, where, why and how much can be all found on the internet. Give yourself a e-dumaction.
-Brett Erskine
