-   Alternative Imaging Methods (https://www.dvinfo.net/forum/alternative-imaging-methods/)
-   -   Agus35 & others, FLIPPING PROBLEM SOLVED!! (https://www.dvinfo.net/forum/alternative-imaging-methods/19471-agus35-others-flipping-problem-solved.html)
Anhar Miah January 8th, 2004 01:02 PM
I have an idea to suggest, which may over come many of the problems that have arisen from attempts to produce an alternative to the P+S technic Mini35mm adapter (namely The agus35 and other variants)
Here is my solution:
Instead of using a camcorder to cature a projection of a 35mm lens why not use a dedicated high resolution MEDICAL CAMERA.
After some searching i have found a camera that will wotk perfectley for the proposed soloution:
http://www.sony-products-for-medical...33-camera.html
This medical camera is a 1/3" X 3CCD hi res camera which is designed to be fitted to micrscopes
Thus this can be fitted into any poject box such as the agus35 or the Static soloution and it can be mounted upside down
So NO FLIPPING IS required and the camera has a DV out (firewire) so all you need to do is attach to a laptop and you a have a direct to disk hi res camcorder with built in NLE and the ability to capture in true 35mm Imageray.
Any comments to this suggestion is highly welcome.
Rob Lohman January 8th, 2004 01:23 PM
It almost looks as though you need to buy it with the control
unit. It claims to even support frame mode.
The following comments:
1) price (probably high)
2) availability (where to get)
3) no recording device (need to bring a laptop for example)
4) power?
Brian Huey January 8th, 2004 01:37 PM
1) $4,150
2) BH PhotoVideo (but it's listed as 'Out of Stock')
3) But you could get it into tight spaces and run a cable to the laptop
4) Looks like it requires AC, if only it could take power through the firewire.
Good idea though, I wonder if there is a cheaper version that's good quality out there.
With this setup you could have 35mm DOF in a compact package that records directly to disk and has manual controls! That would be amazing for some applications.
Cheers,
Huey
Anhar Miah January 8th, 2004 02:06 PM
I think you can connect it too any VTR that has firewire support so you dont need to use a laptop, and if you want to run it off batteries use an inverter they are very cheap and thery allow 12v DV to 240,50Hz AC conversion (sorry i'm in the UK i'm sure you have one for American voltages) check out :
http://www.maplin.co.uk/
and seach for " Invertors " they came in all ranges of powers from 150W to 1KW
so you dont need to use a laptop or even need any mains,
and i think since its DV being streamed from the camera surley you can connect it to a cheap MiniDV camera and use it as a VTR?
Also one other thing, since it is designed for closeup (being connected to microscopes)
it would be better suited than a camcoder to capture a projected image on a Ground glass, if the GG is static it would save on a lot of space.
Robert Knecht Schmidt January 8th, 2004 02:25 PM
Sonoma Health Products (linked above) quotes at $4395.00.
Anhar Miah January 8th, 2004 02:36 PM
HA ha, found another potential camera,
This one only needs 12V DC so no mains inverter required, and its has s-video out as well as BNC type video connector, so you could connect it too a miniDV that allows compsoite video signal in
See : http://rock2000.com/ccd/gpkr222.htm
and there is no reason why you cant mount this upside down
any way theses are some of the specs :
1/2" interline transfer CCD with 768 (H) x 494(V) pixels
480-line horizontal resolution
Minimum scene illumination of 3 lux at F1.4
Signal-to-noise ratio of 50dB
Digital signal processing circuit enables excellent picture quality and advanced functions
A variety of advanced light control functions: --Electronic Light Control (ELC) and Backlight Compensation (BLC)
C or CS-mount selectable
S-VHS (Y/C) & Standard NTSC Composite output
Selectable aperture level
Auto Gain Control
12 Volt DC operation
Filip Kovcin January 8th, 2004 03:21 PM
upside down camera
i think that the original agus35 idea was NOT about - how to invert the image with the NEW camera which you must buy, but how to resolve problem in simple, yet cheap way.
i think that your idea Anhar, may sound mor like "another aproach to flipped image" or something like that, but not "problem solved". problem is solved when you find a proper solution with AGUS35 adapter, or some smart solution near by, but not the new camera.
one can say, ok. i have my dv camera, and i can turn it upside dawn also... what is the problem with it.
i will buy small monitor as you will do, and i'm ok. without a new camera. and disks or whatever media to record the picture and sound.
just a thought.
all the best,
keep agusing!
Anhar Miah January 8th, 2004 04:18 PM
The Agus35 is a good start, but this idea was not just for the agus35, is more about the principle of it.
Even the Mini35 (P+S tecnik) has to invert the image hence light loss etc.. buy reducing this without the need for external monitors and or post flipping. there are many reasons to do it this way.
Yes you are right you COULD just flip your camcorder upside down but that would make all your controls the wrong way and your camcorder was not designed in that fashion.
Using these cameras i.e. medical/security cameras has ceratin features which are very pleasing to the whole aspect of recording a projection on a GG.
I'm just saying there may be a better solution to recording a projection and a 'normal' camcorder may not be the best solution, as with the medical/security cameras also have the advantage of not needing to flip the projection image.
At the ed of the day it is about what is it that you want to achieve?
What i'm after (like many others) is Towards a Film look with DV
(And in my mind right know this seems a good idea)
Maybe a should just start calling this project DIGITAL35 :-)
Joe Ryan January 8th, 2004 05:22 PM
way to think "outside of the box" anhar. very interesting idea.
Helen Bach January 8th, 2004 05:37 PM
There are plenty of camera heads intended for production use (not medical or security) with a wide range of prices that would do this, including native 16:9 2/3" 3-ccd heads. The relay lens between the holographic diffuser (because that looks like the way to go) and the ccd could be an off-the shelf copy lens - very high quality, very fast ones are available.
It should be no surprise that it has already been considered by many people. However, the lack of camera functionality makes it unappealing to me. I believe that using a good upside-down LCD monitor or separate electronic viewfinder is a much better approach if you don't want optical image inversion.
Best,
Helen
Jon Yurek January 8th, 2004 07:00 PM
While a bit expensive, this is a really interesting idea, and I'll definitely be remembering this for later.
Anhar Miah January 9th, 2004 08:53 AM
I've found another device its a VTR that would is PERFECT for this idea
Its the Panasonic AG-DV1 DC its a DV recorder with built in flip out LCD basically its the back end of the DVX100 chopped off!!
It accepts Y/C in/out, analogue audio in/out, microphone in, and composite siganl.
As well as DV in (firewire) so this can be connected to the above mentioned Secuirty OR medical cam to make a complete camcorder it, the size is small it is portabke runs off standard camcorder batteries and accepts both digital video signals as well as analogue signals.
Any way check out these site :
http://www.panasonic-broadcast.com/_...OpenItemID=111
http://www.ebizasialink.com/e-StoreF...index.asp?pg=2
By the way [Helen] the point not using monitors (which i suggested back in the agus thread allthough others may well have mentioned it and thought about it too) is that you still need to flip the video in post at least this way you dont (a) need any external monitors (b) no futher post manipulation
As for the lack of camcoder features, what features would you miss the most?
I think Scott Billups (from pixel monger) has done similar things by making his own camcorder although not using it to record a projection.
I thing the main advantage with this idea is that a medical cam is DESIGNED to be coupled to other optical instraments such as microscopes and capture that picture so it would (i assume) do a better job at capturing a projection from a GG than a camcorder could add to this that its compact and small and has no problem bieng mounted upside down.
Now as for the price i understand that this is a very expensive way to do this, BUT lets throw some figures:
How much does that P+S cost ? about 8K right? and thats not includeing the lens and camcorder so it you can make a system under that price without lens then surely thats got to be a good thing?
I have had a look at many of the footage completed from the agus35 AND others and without trying to offend any one (please do not take this in the wrong manor) i dislike the quality and it seems there is still some hotspots and other image defects, however i do understand that it was done with REALLY inexpensive materials hence ir has too be highly commended (which i do)
Too be honest P+S mini35 have open the floodgates for Indie film makers but the price is not fair.
And Agus showed us what some of us was thinking, that it is not that a expensive to replicate the principle.
I think it may very well be possible to build a system that is better than the P+S mini35 adapter
Anway Guys i thank you for your comments, i will be doing some more reseach on this idea and hopefully may be able to persude my university to fund this! ( have to built an engineering project for my last year OK so its more electronics then mechanical but i suppose the support backets count ;-) )
I may well have the first Digital 35 Camera i always dreamed of!!
Mike Tesh January 10th, 2004 08:36 AM
I already brought this up in the Static 35mm thread. But you've still got an issue. Even if you mount the camera upside down you still need to digitally flip the image horizontally. Why do the job if you're only going to do it half way. Especially at a price that nears that of a mini35.
Rob Lohman January 10th, 2004 08:37 AM
The thing about the lens is a non-issue since you will also not
have a lens for your camera either. So this version and the P+S
version both don't have the lens. If you have a 35mm still lens
I do believe you can mount this to the P+S adapter as well.
Costs. The P+S adapter is indeed around 8K, but you can find
it cheaper second hand and you can just RENT It for the shooting
days you need.
Your solution is already costing $5649,95, that doesn't include
the RODS and other bits, pieces to hook everything up (including
a nice system to power the whole device) and not to mention
the WHOLE assembly of the CD etc. as well (which takes a lot
of time to build thusfar).
ALL of this you WILL get with the P+S and it only costs $2350
more (new). Yes, you will need a camera, but most people here
do already. And you get warranty (on the WHOLE system) and
a *professional* system that you know is going to work (well).
I'm not saying yours isn't a solution either, it was a nifty thought
(I've wondered such thing before as well in regard to shooting
miniatures). I just wanted to point out there is a whole lot more
to think about when doing such a thing yourself and you are
missing components that P+S includes in the package.
I think it is a bit of a gamble, especially considering the high price
and at this moment in time it is not garantueed to work or what
kind of picture such a camera would give (quality wise)!
Things you would be missing would include shutter (I think),
gain controls, zebra stripes / light metering etc. etc.
Iris and zoom control (if the lens has it) will be on the lens.
Anhar Miah January 11th, 2004 02:28 PM
You guys are right this is an expensive method at the moment,
however i'm not suggesting that the cameras i have pointed out be the only ones to use i'm sure there are plenty of cameras out there that might just fit the bill, and if you use a latop you can save on the cost of a poratable VTR, That assuming you have a capable laptop.
But the laptop will produce other issues, i.e no good for handheld work.
But i still believe that a medical cam would be able to capture the projection image better than a normal camcorder obviously i cant prove this, then again i could be wrong.
About the image orinatation on thinking Mike Tesh is correct about this.but surely flipping a monitor upside down would alos mean that your picture is still right to left?
Once again thanking you guys for your invauluable input.
Helen Bach January 11th, 2004 09:06 PM
Hold on, when you turn a camera upside-down, or a screen upside-down you get top to bottom and left to right correction - exactly what is required for this application.
Best,
Helen
Mike Tesh January 12th, 2004 09:36 AM
Actually yeah that's true I didn't think about it that way. Spinning the image around 180 degress will correct for both. What I had in my mind was a flip from top to bottom which would result in the left and right still being opposite of what they should be. As if you were looking at a reversed negative and then flipped it over to view it through the other side. Top and bottom would be correct but left and right wouldn't.
But in this case since you're turning(spinning) the camera 180 degrees to upside down when you spin it back both would be corrected as Helen pointed out. Thanks for fixing that error.
Nicholi Brossia January 12th, 2004 10:02 AM
I'm just hoping that the new camcorders, coming later this year, have a menu selection to invert & revert (or rotate 180 degrees) the image to be recorded onto tape. Its all electronic and they've already done that for the lcd screen. So, according to my simple logic, rotating the taped image wouldn't be hard at all. That way, these adaptors would become much much simpler in design, and even more effective.
Here's hoping I guess.
Anhar Miah January 12th, 2004 12:18 PM
So far does anyone know how 'clean' an image one can achieve with a still GG/holo diffuser/other?
Filip Kovcin January 12th, 2004 12:49 PM
how clean?
as clean as difuser or GG is clean :))))
just kidding,
sorry guys, but i couldn't resist.
it's dificult to say - you must judge for yourself.
in my agus35 the image thru GG is in my opinion "clean" but it tooks a lot of light when shooted in poor lighting conditions.
with static GG you should ask Daniel Moloko - it's on the other thread, started by louis feng. Daniel is for now the only one who has pure static GG. and he DID the testing and some shoots.
there are some samples also there.
filip
Bob Hart March 29th, 2004 09:50 AM
An option, rather clunky I've tried is to operate a PD150P upside down with a small 4 inch monitor mounted on a plate bolted to the tripod mount.
In bright daylight, the monitor can't be seen too well but the camcorder itself tolerates being held inverted. Retraining the left hand to operate the controls is not too difficult.
Before you do this however you should ensure the cassette enclosure is very clean as you don't want bits of debris coming back off the bottom into the heads or the tape cassette itself.
It becomes a question of self-confidence if you want to work the camera this way in public. People do stare and I can assure from prior experience that you will feel like an idiot.
Helen Bach. Given your interest in things film/video, is there any family connection with Bach Auricon? the outfit which developed the film transport which last appeared in the legendary 70s CP16 news cameras.
Dan Diaconu December 10th, 2004 09:22 PM
About GG movement
Hi guys,
I have developed three different DV adapters since
August 2004.
Considering that the signal from tape is in the same (frame size) for any DV camera, I choose Panasonic 200 (3ccd,manual focus, iris) over any other PD170 and such.
(All the features on any "expensive" model are of no use to
me in getting a "filmlike" image since I am using the adapter)
Best screen (that I found) is a plain matte focusing screen
of Nikon or other Minoltas..... (from the 35 mm cameras)
They are (as required) fresnel on the front, matte on the back)
The rest of the optics are just the same as 35mm SLR.
GG movement pictures here:
http://pictures.care2.com/view/2/361042290
Cheers,
Dan
Dan Diaconu December 10th, 2004 10:56 PM
Viewing image on LCD
Any electronics store have a headrest monitor for DVD players.
Most of these LCD's have a mirror function (left right) and a mercury
switch (vertical flip)
Open th back, permanently solder the switch and that's your
"normal" viewing monitor (if the displayed image is flipped abck to "normal L-R and U-D)
Hope this helps.
