-   Alternative Imaging Methods (https://www.dvinfo.net/forum/alternative-imaging-methods/)
-   -   EX-1 with the letus and anamorphic lens (https://www.dvinfo.net/forum/alternative-imaging-methods/119124-ex-1-letus-anamorphic-lens.html)
Mark David Williams April 11th, 2008 08:49 AM
I have my EX-1 with the letus extreme a pentax 50mm lens which has a 49mm thread with an iscorama 54 anamorphic lens with a step down ring attached. I cant seem to get good focus. Even at 15 feet away. Could it be Im using a smaller part of the iscorama lens? Seems to work fine if I attach the iscorama directly to the EX-1?
Eric Pascarelli April 11th, 2008 09:08 AM
Are you able to get good focus with that arrangement on a stills camera? Do you have the equipment to try it?
Mark David Williams April 11th, 2008 11:46 AM
You mean use the pentax lens with the anamorphic adapter on a stills camera? Good idea! The focus looks OK and lines up perhaps a little soft but then its hard to tell. Looking through the still cameras viewfinder.
