Official Sumix SMX-12A2C FAQ at DVinfo.net
Alternative Imaging Methods
Old March 29th, 2008, 08:18 AM   #1
Hi all,
Farhad and Sumix want to hear (or read) what you want to know about their SMX-12A2C cam. They also want to know what you want from this cam. So I'm opening the Official Sumix SMX-12A2C FAQ.
From now on, please post all your questions and possible improvements here.
(This first post will be updated whenever a new question is answered for easy reading)
Q&A:
_______________________________________
Jose A. Garcia is offline   Reply With Quote
Old March 29th, 2008, 08:19 AM   #2
SMX-12A2C main specs:
* 2/3" optical format
* 1920x1080 Imaging at Standard 2/3″ Optical Format
* 12bit Output with >11bit Dynamic Range
* High Efficiency Microlens Array
* RGB Color Filter Array
* Electronic Focal Plane Rolling Shutter
* Progressive Readout with Rolling Shutter
* Green Responsivity (550nm): >5000 LSB/lx-s
* Patented Low-Noise, High-Speed Video Architecture
* Frame Rate up to 60 fps progressive, with maximum sensor resolution
* Output Bayer Raw Data 12 and 8 bit per pixel
* Extended Sensitivity 60 fps at 1280 x 720 (2/3 inch)
* 120 fps at 1280x720 (1/2 inch)
* Variable Electronic Shutter:
- Synchronizable to External Shutter/Flash
- Synchronizable to External Frame Synchronization clocks
* Dynamic Noise Reduction (DNR)
* Vertical Line-Mixing including 3->2, 2->1, 3->1 and 4->1 Modes
* Horizontal Pixel-Binning including 1.5->1, 2->1, 3->1 and 4->1 Modes
* Enhanced Sensitivity 2/3-inch Video Using Pixel Binning and/or Line Mixing
* Video Gain from -24 up to 72 dB; independent control of R, G and B channels (for SMX-12A2C)
* Sub-Sampling Modes Optionally Provide 1.5, 2, 3 or 4x lower resolution
* Windowing with 16 Column and 9 Row Resolution
* Gigabit Ethernet full duplex mode Interface
* Ethernet cable length up to 100 m
* Power Over Ethernet IEEE 802.3af compliant or external power: 5 V (500 mA)
* Hardware image processing (Gamma, brightness, contrast, median filter, lossless image compression)
* Hardware Conversion Table from 11 bit (12 bits output with >11 bits dynamic range) to 8 bit per pixel
* Hardware lookup table separately for R, G and B colors
* Operating temperature: from 0 to +60°C
* Lens mount type: C-mount
* Weight: (without lens) 198 g
* Dimensions (W x L x H): 50 x 80 x 50 mm
* Camera housing material: duralumin
Old March 29th, 2008, 12:11 PM   #3
Because 12A2C have inside camera head processor:
possible implement CineformRAW in silicon and transfer through
GiGe to portable NAS based on 2,5" HDD or SD/CF card?
Love to see taken the best things from SI2K and Elphel :)
Serge Victorovich is offline   Reply With Quote
Old March 29th, 2008, 12:52 PM   #4
This is great!
I think a practical way (decent software capture solution) for NORMAL people to operate the camera in NORMAL circumstances (eg. outside on the street) would be excellent. Ive seen MANY attempts of people tryna do this with no results so far.
Alot of people recommend the silicon UI - that would be great!
Ive seen somewhere on this site a good cheap laptop chestmount, just plug the cam via gig-E and shoot - surely thats straight forward? I mean normally the computer/settings part of a camera are on the cam itself which is not ideal.
IMHO I think the laptop rig is the best because the cam itself is small, light, and the settings are a proper software UI based with big/high res monitoring!
I hope Im not misinformed and this makes sense?
Nicky Campos is offline   Reply With Quote
Old April 5th, 2008, 09:05 AM   #5
Is there a list of notebooks that have been tested with 12A2C?
Or more general: Which notebook-chipsets have enough GigE performance to capture with the 12A2C at 1080p 25 fps 12 Bit RAW?
(the chipset in my PC seems to have very poor GigE performance)
When will RAW recording be available?
Gottfried Hofmann is offline   Reply With Quote
Old February 6th, 2009, 07:18 AM   #6
Why is this thread dead ?
Interesting camera. Yet no one's talking about it ?
Anmol Mishra is offline   Reply
