-   Alternative Imaging Methods (https://www.dvinfo.net/forum/alternative-imaging-methods/)
-   -   matte box & filters (https://www.dvinfo.net/forum/alternative-imaging-methods/106255-matte-box-filters.html)
Paul Mailath October 22nd, 2007 10:23 PM
matte box & filters
I'm waiting on the Letus Extreme to land on my doorstep and wondering if I now need to buy some ND filters and suitable mattebox.
As I understand it, there's no point in using the ND filter in the camera (XH-A1) if I'm using a 35mm adaptor.
What other filters are people using?
Are they screw on or 4x4?
Steven Dempsey October 23rd, 2007 01:04 AM
Actually that is true of many other adapters but with Letus adapters, you can very effectively use the camera's built in ND filters.
Dennis Wood October 23rd, 2007 02:10 AM
There are a few schools of thought on the topic, but once you've played a bit with lens flare, and seen the contrast hit that lens hazing causes, a mattebox and 4x4 filters are hard to beat. Built in ND filters work great to cut exposure, keeping shutter speed and aperture in desired ranges, but they don't prevent non-image forming light from causing issues with your optics out front. A graduated ND filter as well as a polarizer are two extremely useful filters that not only cut exposure a few stops, but also improve image quality outdoors. For example, a graduated ND can be adjusted in the stage to cut 2 stops in a bright sky, but leave the lower half (ground) unaffected. If you point your adapter/lens beneath a lamp so the light is just out of view, try shading the lens surface with your hand for a very visual example of lens hazing and contrast loss. The mattebox shades will stop this, and are a win-win when it comes to image quality.
Once you start using one, you'll never leave home without it. End of "I love using matteboxes" post :-)
Paul Mailath October 26th, 2007 06:23 PM
Thanks guys
(sigh) another addition to the wishlist - does it ever end?
Malcolm Ong October 28th, 2007 03:57 AM
Originally Posted by Paul Mailath (Post 765547)
Thanks guys
Nah. It never does
