The sound of the Letus
The motor is virtually silent when running, making it practical to still use the built in mic.
Here's a quick sample I shot with the Letus, motor engaged: http://www.pinelakefilms.com/letus/letus_sound.wmv |
I like it, crickets and a trickle of water; that's quiet! I just placed an order for the 35FE. I'm excited, seeing the quality of the video.
I have a question about lenses. The Letus was a good investment, but it set me back a bit. Doing a quick search for compatible lenses on B&H, I found some inexpensive brands. (Phoenix, Vivatar, Tokina.) Does anyone have experience using these brands? Or should I look for higher quality used equipment? Thanks! |
I use Nikon lenses and I bought all of them on eBay without a problem. I would recommend either Nikons or Canons.
Which lenses do you use? Obviously a 50mm but what else?
I'm wondering which noise do Brevis and Redrock produce.
Steven, I read a couple of days ago you had that merlin sabilizer. Did you already take anything with that thing? regards |
Haven't had much time to do much with the Merlin yet. I'll post something when I do.
The lenses I use with the Letus are: Nikon 28mm f2.8 Nikon 50mm f1.8 Nikon 100mm f2.8 |
| All times are GMT -6. The time now is 11:23 PM. |
