Rode VideoMic or NTG-1 for distance?
What kind of distances can I shoot at and get a decent monologue with these mics? Which is better for shooting from around 5-6 feet? I heard some samples on this page:
http://pana3ccduser.com/article.php?...%98DE-Videomic Where a guy stood 5 feet away using the VideoMic and it sounded pretty good to me. |
Well do keep in mind that I'm also not filming a hollywood epic, just a simple music instructional DVD. If I were to hang the mic above the subject and out of the frame, would that work? That would probably be more along the lines of 2 feet but it's not directly in front of his mouth either. hmm..
The NTG-1, NTG-2, and VideoMic are the same microphones in different packages. The NTGs are phantom power-able, made of metal, and use the XLR connection. The VideoMic uses a 9 volt battery only, is made of plastic, and uses a 1/8" jack. I agree that these mics are not good for dialogue recording. Inside you will get a lot of echos etc. Go for a cardioid or omni lavaliere mic for recording in your situation.
HATE lavs, I have one now and I want to throw it on the ground and smash it into a million pieces. All the rubbing sounds and everything else that comes with it, no way, not anymore, got to find something better. I never really thought about having the mic IN the video frame.. I'll suggest it and see what they say..
For the person that suggested a "cardioid" does Rode make one of those? |
The S2, NT55, and NT6 are cardioid (or come with cardioid capsules), although I haven't heard them before. The S2 seems more suited to hand holding, but the NT55 could be boom mounted.
"All the rubbing sounds and everything else that comes with it, no way, not anymore, got to find something better."
There is nothing better than getting the mic closer. Nothing. A mediocre mic a foot from the talent's mouth is going to sound dramatically better than an expensive mic six feet away. There should be no rubbing sounds from a lav unless you are putting it under clothing. Even then, there are ways to reduce/eliminate rubbing. If you have a decent wireless, you shouldn't be having ANY serious issues. If you are having problems with the right tool for the job, you should adjust your technique. Don't search for a less optimal solution. If you had a camera problem, you wouldn't switch to a pencil and a sketch pad. How are you positioning your lav? Are you getting reception problems? What brand and model are you using and what frequencies does it occupy? |
For similar situation I would use my Rode Nt3, it does great work inside and is versatile. You can boom it, but the mic is a bit heavy.
