-   -   Portable Mic Pre-Amp (https://www.dvinfo.net/forum/all-things-audio/9320-portable-mic-pre-amp.html)
Rob Wilson May 5th, 2003 06:41 PM
A search on the board didn't come up with a solution so....
I'm using a ElectoVoice RE50/B mic for field ENG work. I need a recommendation for a inexpensive (right, like anything in this field is inexpensive) mic preamp to feed a portable microwave transmitter. It needs to be battery operated, XLR in and out and would be great if it had adjustable gain and a peak indicator. Any suggestions??
I've found the Shure FP 23 which would be perfect .... Except its $400. Thanks!
Ken Tanaka May 5th, 2003 07:05 PM
Rob,
The Sound Devices MM-1 is top-notch and would more than fill your bill. But it's $475.
Ken Tanaka May 5th, 2003 11:36 PM
Rob,
As a less expensive alternative, take a look at the Rolls PM50. Brian Dickman noted this in a thread a while back.
Peter Kulka May 6th, 2003 12:11 AM
I just designed one of them for my aplication.
If you are capable to build it, than I can sent you schematic.
Will run on 1.5 to 9 V battery and has adjustable gain from 0 to 10dB. Also is equiped with input and output transformer and selectable ground.
Cost to build this unit for one microphone will run about $30.
Rob Wilson May 6th, 2003 11:08 AM
Ken, acutally have the Rolls box, works great for a boom op with headphones but the XLR mic connections are just hard wired pass through, not amplified at all.
Peter, appreciate the input but building a board is beyond my abilities. If its a kit that just needs assembly, I'm up for that!
Thanks to both. I'll keep looking. Hard to believe there isn't a simple box for this.
Marco Leavitt May 6th, 2003 01:58 PM
It sounds like you're looking for one of those "battery boxes" that mini-disk owners frequently use to make bootleg recordings of concerts. Try doing a search at www.minidisc.org.
Pierre Petit May 16th, 2003 09:10 AM
Hey Peter, i'm interested in the schematics. I need a pre amp but now i dont have the funds to buy one.
