-   -   What's the cheapest midi keyboard I can hookup to a PC? (https://www.dvinfo.net/forum/all-things-audio/91752-whats-cheapest-midi-keyboard-i-can-hookup-pc.html)
Anthony Vincent April 17th, 2007 05:24 PM
Sam Rosado April 17th, 2007 05:31 PM
M Audio has a 49 key controller for $99
Graham Hickling April 17th, 2007 11:08 PM
You can use your regular keyboard as your midi controller, if you are feeling especially cheap: http://www.bome.com/midi/keyboard/
Sam Rosado April 18th, 2007 01:05 PM
I cant beleive you actually said that!
Evan C. King April 18th, 2007 01:40 PM
Said what? It's true you can use a real keyboard, for a while I was using my old Yamaha with a midi to usb converter box, they're not expensive.
Colin Willsher April 18th, 2007 01:53 PM
It might be wise to make a distinction here. If you want to hook up a MIDI keyboard to a PC, the PC will also require a MIDI interface. Is this something you have already?
If not then you might want to eliminate that additional expense and investigate keyboards with a USB connector. The M-Audio portable keyboards have both MIDI and USB, as do many modern models I suspect, but if you already have a MIDI interface there are many MIDI only bargains to be had on the second hand market, where you will get much more for your money.
Happy shopping!
Colin
Sam Rosado April 19th, 2007 01:02 PM
sorry, i though you meant the computer keyboard.
Sam Rosado April 19th, 2007 01:05 PM
[QUOTE=Colin Willsher;662687]It might be wise to make a distinction here. If you want to hook up a MIDI keyboard to a PC, the PC will also require a MIDI interface. Is this something you have already?
my opinion is that midi is dead for a controller. USB controllers can be powered by computer, and there is no need to buy interface. that doesnt mean midi itself is dead, but USB is more reliable. No midi echoes!
