Lav rustle
I've been using the Sony ECM-44B as well as the Countryman B6 and also the COS-11 for interviews. Both the COS-11 and the Countryman are susceptible to rustle problems with clothes (and subjects who won't sit still!). It's not the mic itself which I mount in plain view, but the cable from the mic to the XLR cable. The Sony doesn't have that problem, but I prefer the sound of the other mics. Does anyone have any ideas of how to tackle this? Some sort of cloth covering? Thanks.
Yup, broadcast loop is excellent for cord noise. Moleskin is good to prevent actual mic friction noise.
And a baseball bat for when they move one too many times.... |
Rycote Stickies and Undercovers can also help |
Wow. The broadcast loop works beautifully, although I don't know why. I don't suppose it matters. I can't figure out how to do it w/ the B6 because my clip doesn't have the hoop thing. I'll check their web site for another clip.
I hadn't thought of a baseball bat ... untill now. Thanks. |
In addition to the loop, especially if the subject's clothing is very thin material, I use a small backer to help keep the mic still in relation to the clothing.
The thin neutral-colored cardboard on the back of a notepad works well for this. Cut out a piece about 1 inch square. Then nip off all four corners. The corners can stick the subject, as well as generate their own noise against the clothing and the backer will be less likely to show through the fabric without sharp corners, so it's an important step. From the outside to the inside you'll have: the mic the mic clip the fabric a loop of gaffer's tape a little smaller than the cardboard the cardboard a smaller loop of gaffer's tape the jaw of the mic clip You can also secure part of the loop of cable in or under the smaller loop of gaffer's tape and the jaw of the mic clip. Just don't let the jaw cut into the cable if it's sharp. As long as the rest of the cable also has some slack in it, then the mic will ride with the clothing and the subject can move without causing too much noise and you don't actually have to stick anything to the subject's skin. The kit that comes with the AT899 lav has a magnetic clip which works in a similar manner. |
| All times are GMT -6. The time now is 06:28 AM. |
