-   -   battery/phantom power? (https://www.dvinfo.net/forum/all-things-audio/75622-battery-phantom-power.html)
John Dombrowski September 16th, 2006 09:10 AM
Can someone explain why a mic with both battery and phantom power costs less than the same mic with phantom power only? Why would you not want both?
A. J. deLange September 17th, 2006 09:47 AM
Phantom power is usually supplied at a reasonably high voltage - more than in required to run the preamplifier in the microphone. If only phantom power is present then circuitry is required to derive the lower voltage for the pre-amp. If a battery is also present then the high phantom voltage can be used to bias the capsule while the lower battery voltage can be used to operate the preamp. It's a pretty shaky hypothesis but about the best I can come up with.
Steve House September 17th, 2006 11:28 AM
There can be several explanations depending on the mic. Condenser mics that have an internal battery invariably are based on permanently charged "electret" mic capsules which are often (though certainly not always - there are many very fine electret based mics out there) considered inferior to "classic" condensor mics that require full phantom power. Also the dual power battery/phantom mics are somewhat larger and heavier than the same mic in the phantom only version in order to make room for the battery. For example, the Rode NTG-2 is 2.5 inches longer than the NTG-1 and a couple ounces heavier yet they are the exact same mic except for the powering.
Dave Largent September 17th, 2006 03:34 PM
"invariably"? NT4. NT3.
Steve House September 17th, 2006 04:28 PM
I stand corrected - let me rephrase to "internal battery-powered mics usually are based on a permanently charged electret capsule ..."
