-   -   wireless mic questions (https://www.dvinfo.net/forum/all-things-audio/72262-wireless-mic-questions.html)
Joe Thatcher July 25th, 2006 03:16 PM
Is it possible to use a wireless mic on an xl1s and the stock canon mic at the same time? Any help would be apreciated thanks.
Logan Bright July 26th, 2006 06:40 PM
I don't know about the XL, but in my experiences, when using an external microphone, the camcorder's built-in mic is shut off by default. As far as I know, there is no way to record 2 separate audio tracks to a single tape that way.
Guy Cochran July 26th, 2006 07:20 PM
The Canon XL-1S can record 4 channels of audio.
Use Channel 1+2 for the on-board stereo mic
Use Channel 3+4 or just 3, or 4 for your wirless.
You will need to switch into 12Bit (32kHz) mode for 4 channel audio.
Depending on your NLE, you may also need to to capture the audio in two passes.
Find more info under audio at http://www.dvinfo.net/canon/articles.php
Joe Thatcher July 26th, 2006 11:10 PM
thanks guys for the help
