-   -   SK 100 transmitter work with dynamic mics? (https://www.dvinfo.net/forum/all-things-audio/71384-sk-100-transmitter-work-dynamic-mics.html)
John Willett April 18th, 2013 03:57 AM
Re: SK 100 transmitter work with dynamic mics?
Originally Posted by Larry Vaughn (Post 1791066)
I have a similar question. I have 2 of the EW-100 G2 mic transmitters. So they don't provide any phantom power
Can I assume that any mic plugged into any of the G2 EW-100 systems is a dynamic mic?
I what to be able to use the plug in mic transmitter with a lav mic, for example. They just sit around most of the time and maybe with an 1/8" to xlr adapter I could make use of them?
That way I'd just find a used receiver, and add to my capabilities.
To use a dynamic mic. with the SK 100 transmitter you will need a special cable.
The SK 100 puts out 5V DC plug-in-power voltage to power an electret tie microphone (eg: ME 2) - so - to use a dynamic mic. you will need a special cable that includes DC blocking capacitors in the XLR to prevent this DC voltage getting into the microphone.
Bruce Watson April 18th, 2013 09:22 AM
Originally Posted by Dave Largent (Post 511395)
The bodypack transmitter works with a handheld
dynamic just fine. You just need the XLR-to-locking 1/8" adapter that Senn sells. Costs around $20 or so.
I've done it. I would say it works, but a lot less than fine. The problem is that the dynamic mic signal needs a lot of amplification, which puts the bodypack transmitter at the upper end of it's capabilities. Which makes for a noisy result.
Far better, cleaner result comes from the http://www.bhphotovideo.com/c/product/618848-REG/Sennheiser_SKP_100_G3_A_SKP_100_G3_Plug_on.html that's designed for exactly this use. Much better resulting signal. If you want professional sounding wireless audio using a dynamic mic, use the SKP 100 plug-in. Really.
