How to mic an engine of a moving car?
I'm trying to mic an engine of a moving car as it shifts up to top gear. What the client wants is to have the engine sound captured as he reaches top speed (> 100 mph) while I am video recording various dials, tach and speedometer.
For better or for worse (probably worse), I taped my AT-897 to the plastic computer case inside the engine compartment and ran it into an iRiver. We did several runs and got beautiful sound. The mic was hot but I could still hold it in my hand. The mic is surrounded by lots of air space and does not come close to the engine. I realize that oil and other nasty stuff is flying around inside so I'm hoping there is a way to get good sound without exposing the mic to the bad stuff. I have the Giant Squid mic that I may consider using next as a sacrificial mic. I'm also wondering if the sound pressure levels are too high for the mic. The client mentioned that during dyno testing, the engine sound was earplug loud. But that was in an enclosed space. Listening to it from inside the car with the windows rolled down, it seemed like the mic should be able to handle it. Its maximum input sound level is rated at 115 dB. The total time the mic was in the engine compartment was about 10 minutes and the car is a 2006 Honda Civic. |
i think your on the right track, your not using an overly expensive mic like a b6 or a cos-11.
i think you should just add one of the rycote cover-up thingies to protect the mic a little bit. you could add a variable pad to the mic and try different amounts like -10, -20, -30 ad see if you can hear any real difference. if this guy is doing major mechanical modifications to the cars i'm sure he could easily run an xlr cable for you through the firewall so you could run the mic into a camera or recorder inside the car and be able to hear the sound your self. plus then you could change the pad settings much more easily. matthew |
Are you after actual "engine"noise? (mechanical sounds)or representative sound(exhaust)?I have recorded a fair bit of sounds of vintage muscle cars eg. Hemi Cudas,Yanko Camaros,etc. and the combination sound of exhaust and a little mechanical mixed certainly is representative of engine horsepower and rpm.What is the actual purpose of the recording?
Check out the sounds of the cars at this site.http://www.legendarymotorcar.com/home.htm |
Any pads to recommend?
I like the idea of the variable pad; any that you recommend? You gave me the idea to hook up the sound to the camcorder - but instead of a mic cable, I'll try my Sennheiser SKP 100 G2 plug-on transmitter to give me the live feed. It will be easier than trying to synch up the iRiver audio. |
Looking for less muffled noise
How do you recommend recording the exhaust? I'm concerned about securing it without damaging the car or the mic. I will probably want to use the Sennheiser SKP 100 G2 plug-on transmitter if this is possible. I tried most all of your links but could not find any sounds. I must be missing something obvious. |
shouldn't you try and record from several areas and then mix them down? from the rear you need tires grabbing and tailpipe rumble ,from the inside you need the stick shift click and from the front you need the whine as the engine revs. however at some point the engine compartment pressure will be to great and the mic will no longer get a "clean sound" so under the hood can be recorded in park with hood up and foot on gas??
Yes, I should get those too
Robust dynamics
At these sound levels, especially inside the engine compartment, wouldn't a dynamic SM58-ish mike be an option? These mikes will be able to withstand a lot of abuse. They're cheaper too.
Dirk |
Good idea - I do have an SM58
An SM57 mounted to the body near the tires should be about what you want, and it's a cheapie. Durable as anything, you should be able to get a variety of sounds just on placement.
Recently put a wireless lav inside a motorcycle rim and moved the bike at medium speed to get the sound of the road/tire/hub sound, it came off quite nicely until the bike hit around 40 mph and tossed the transmitter off. |
I'll look under the body
One tip I have for you is put you equipment in a ziplock baggie, clip cornor for the cord to feed the mic out when you put it up under the car. I would look in the bumper area on alot of the newer cars is areas they have the space and coverage needed. Good Luck!
Omni Directional mics have the best freq. response, and dynamic range. Directional (ShootGuns) are the worst and will distort some of the freq. ranges.
Think of the car as a philharmonic orchestra, you get different sound in each area. Monitor the sound from different areas in and out the car, let the "Mechanic" be the conductor, Give him good headphones and he will decide what is the sound he likes best. |
Thanks for the tip
My Giant Squid is an omni
| All times are GMT -6. The time now is 07:06 AM. |
