Sound Advice
Ok I like to grab sound independently via DAT using a soundman
my old faithful AIWA HD-S1 has packed up so Im in the market for a new DAT portable preferably with balanced XLR inputs whats out there? any recommendations? |
Both Tascam and Sony make portable field recorders. What is your budget?
Jeff |
hmm
DAT field recorders are very pricey so I am seriously considering using my notebook to record sound If I wire up a stereo mini jack as balanced 2tip 3ring and record stereo in SoundForge through the stereo mic input, I will have normal sound on left and inverted on right which I can later subtract from each other to get the 6db gain with noise cancellation, plus if I run the notebook in mobile mode I will have four hours on the battery - thus up to four hours continuous recording at full bandwidth 48Khz with a nice big display my notebook is very quiet from about 2 metres with the advantage of no scratchy sounds when input levels need adjustment has anyone used their notebook for recording ? any pitfalls I havent figured yet? |
I purchased a Tascam DA-P1 recently, I think the extra cost will be worth it. I know it's not always the best but considering how durable these recorders are you might want to check out eBay for a used unit. Of course, take some time to talk with the owner before buying. But I see that a few have gone for around $600 or so on eBay, which is great considering they are $1500 retail (suggested price is at a ridiculous $2100). Then there is the Marantz CDR300 portable CD burner unit with XLR inputs at around $600 brand new. I've never recorded from a laptop, sorry...
Chris
the DA-P1 is a very desireable tool, but to be honest with you the more I experiment with my notebook the more I like the idea of recording direct to it. I have done some soak tests and found that I can have Soundforge running with some real time DX plugins to give me multiband EQ and a warm compressor and reverb if I want it - all running to the hard drive live. This of course cancels the need to grab DAT to the hard drive for later sync with the video so there is a workflow benefit too. |
I think the deciding factor could well be who you record audio for and it's intended use. If everything is to be edited by you, on your computer, then a laptop has some distinct advantages as you have discovered. On the other hand, if the work is to be done on different computers or at a remote location, then you waste time dubbing DAT copies (you'd need to rent a DAT etc.) for your client.
Thanks Jeff
I suspect burning off a few CDs would be the way forward in such case, in 80 min chunks sure would outperform dubbing DAT copies in realtime and a lot cheaper and more universally acceptable |
I don't think the slight loss of audio quality would be noticeable.
| All times are GMT -6. The time now is 11:09 PM. |
