At 9.29" (236.0 mm) in length, the AT835ST provides broadcasters, videographers and sound recordists professional quality stereo audio in a microphone that resembles a monaural shotgun mic. That means the AT835ST is easy to use with standard camera mounts, shockmounts and windscreens. Engineered for long-distance pickup in broadcasting and film/TV production, this compact M-S stereo shotgun features internal matrixing innovations that allow for stereo audio with or without an external matrix. It also features switchable low-frequency roll-off and independent line-cardioid and figure-of-eight condenser elements. "THAT RESEMBLES A SHOTGUN" The idea that a stereo shotgun is a mic that has two far reaching lobes is erroneous. Regards, Ty Ford |
I'm not arguing - I've just never used a stereo/shotgun mic. I've done a lot of MS recording, with a variety of Mid patterns, and I'm familiar with the math of the "virtual" stereo signal. So, theoretically, by math, and empirically, based on MS recordings with everything from omni mids to hypercardioid, it seems vaguely possible that a shotgun + bidirectional could give some sort of stereo effect with more reach than a cardioid or hyper M MS setup. If you've played with the math, the virtual mic looks like two farther-reaching lobes. Now, I know this is extremely dependent on mic placement (since the side pickup may very likely be exposed to things the mid is highly rejecting, as distance to source grows). And I'm not sure there's a clear definition of "shotgun"... but it seems like something at the far-reaching end of the MS continuum is not implausible. Again, I've never used one of these... I can imagine that they just don't work well in shotgun situations. Just curious what your response would be. |
If you only have one forward-facing element (and every stereo/shotgun I've seen has only one) then it's not possible to have two forward lobes.
Regards, Ty Ford |
Looked at another way, the side element of an M-S config. is a figure-8 element. Let's say we do what Barry suggests, and use a shotgun for the mid element. Ignore for a moment what that sounds like (I've not tested it) and let's consider directionality. We still have the side element, basically not directional at all. Any sort of M-S array is sub-cardoid in response. Seeking side rejection, we start decreasing the volume of both the plus and minus side signals. Voila, we have increasing side rejection. BUT, we're losing stereo effect. By the time we've decreased the side volume to the point we have the directionality of a shotgun mic we have no meaningful side information nor any stereo image - we've got what Ty suggested several posts ago, a mono shotgun microphone. I guess the math that Barry is doing indicates that Side plus a shotgun Mid looks more directional on paper than Side plus a cardoid Mid. I can see that, but I believe that is purely at the expense of stereo image. If you wanted the same stereo image with a shotgun Mid as acheived with a cardoid Mid you'd be adjusting relative gain M vs. S to the point that math shows the same polar response (as a rig with cardoid Mid). That is, you'd decrease the Mid gain relative to the Side gain, losing apparent side rejection. Except the image may fall apart due to the increased directionality of the Mid element - I've not tested it. Well, I've got it clear in my head but it's difficult to write about. It'd be easy to demonstrate and diagram. But hey, you might like the sound of a shotgun Mid element and decreased Side gain - if it sounds good, it is good. I've certainly struggled with a big mike stand in the 3rd or 5th row of an audience, but screw 'em, good sound is worth it, right? ;-) I really get pissed off when some "picture" guy says we can't have a mic there, it's in the shot. Where are their priorities? Just kidding, but not really. There is certainly tension over these issues, and I'm always looking to fly mics, or lower profile mics, or some way to keep the mics where they sound the best. "We have met the enemy, and they are us." - Pogo |
I see part of the issue here with how we are looking at it. I think you guys are thinking stereo by spliting the head in half and out the ear on each side is the 'center' for each?
Consider a marching band on a football field in front of you. The contras (tubas) are on the right, the drumline (battery) is on the left and the tenors (trumpets) are in the center. The elements are 90 to 120 degrees apart and at 45 degrees apart. You hear the texture and they can play with serious seperation. All of the main elements are in front of you. You do want to reject anything else. And it sounds flat in mono while not matching what you are seeing. The best setup I have seen is a cross over pair at the 50, and a left and right at the 35. They also do a couple at the crowd and maybe one on the opposite side (the band will play away for soft sounds). I think I remember it like that at DCI finals, although they may have also had to mics at each 45 too. Me, I get no setup time and run onto the edge of the field. I need to capture stereo to catch the texture and reject side and behind. What would you use? ;) Stereo shotgun? :P 5.1 is better because you can get in the 'middle' of the field. Too much stuff to carry onto the field with <2 minutes to setup. Side note, I bought Mr Videos disc of the semi-finals this year. I was on the DVD on the sidelines at Gillette Stadium. :D |
Again, I've never used a "stereo/shotgun". But the whole point of MS is that it indeed provides "virtual" forward facing lobes, and the width and reach of the image can be adjusted by the MS ratio. Cardioid has more reach than omni. Hyper has more reach than cardioid. And, I'd assume, shotgun just adds more reach on top of that. The stereo image, though dependent on the situation (esp. how close the mic is to source vs. side "distractions"), of course tends to get a little strained when the mid is more diectional than a narrow cardioid, but again, it's a continuum. There are indeed still "virtual" lobes with a shotgun/8 combo, and they're reachier and more forward-pointing. They may just sound like crap. It may be hard to match shotgun and f8 frequency responses. There are likely many reasons why it's not a great approach... but it's still a point on the MS continuum that's as much MS stereo as any other combo.... |
Guys, just in case - I'm NOT advocating the use of a stereo shotgun or stereo/shotgun. At least not for any situation I could think of. I'm just exploring the supposed "impossibility" of such a thing. It's not impossible; in fact, it's not at all out of line with any other form of MS. |
Barry,
Go out an get a shotgun and leave your theoretical universe for the real world. Now you're talking about Wes Dooley and TWO Bi-directional microphones. SHOTGUNS AREN'T MADE FROM TWO BI-DIRECTIONAL MICS. I think you have expended the universe. Ty Ford |
What do you have against Wes? I'm just pointing you to some of the seminal papers. They're nice! Read 'em. Anyway, thanks, though! I have ALWAYS wanted to expand the universe! I'm gonna go stretch it some more. |
Anyway, FYI, Electronic Musician is focusing on MS techniques this month, for anyone who wants something a little less techy than the articles/books I referenced...
Then there's mics like the Sanken CSS-5, produces a 'directional' stereo field. Takes 5 elements to do it and not exactly cheap.
