-   -   To improve the sound of the PRIME X299-DELUXE video card? (https://www.dvinfo.net/forum/all-things-audio/536824-improve-sound-prime-x299-deluxe-video-card.html)
Paul R Johnson June 20th, 2019 02:55 AM
Re: To improve the sound of the PRIME X299-DELUXE video card?
I thought about Graham's comments and I suspect that I too am perfectly happy with the output quality of practically everything nowadays - the killers being hums and noise just from the interface. I dug out an old Maya card the other day - 4 outputs from an ancient recording system, and managed to find some drivers and it's running some theatre replay kit - it worked brilliantly in my studio, but ground loops/and other connection issues mean it's connected via a DI box, with floating grounds to make it silent. It's got to be fifteen years old technology and sounds no different to anything else. now we hear mics, we hear loudspeakers, but so much of the rest is tiny differences that mean little. I n' remember the last time I hated the sound of a piece of kit. I just wish I knew what the OP actually means.
Adriano Moroni June 20th, 2019 09:41 AM
Hi friends, I don't have any good headphone to do some tests. I'm sorry, but I'd like to ask a question, maybe asked by an inexperienced person.
Is there anyone doing video editing completely with an headphone?
Is it stupid to do this or can it be done?
Seth Bloombaum June 20th, 2019 09:50 AM
Lots of people edit on headphones.
Nobody should be doing their eq, compression, or mixes on headphones, unless their viewers will be wearing headphones.
Headphones sound different than speakers. They tend to overstate quiet parts of the mix, meaning, you’ll tend to mix music too high, and not realize when dialog can’t easily be heard.
Adriano Moroni June 20th, 2019 09:55 AM
Thanks for your suggestion. Now I understand better.
Graham Bernard June 20th, 2019 09:59 AM
If you’re only going to watch your videos and it’s only you who’s gonna watch/listen to your work then maybe. Seriously, I need to hear the power and depth of my Audio supporting and adding to my video via Monitors. There is a difference. Cans are great for analysis of the ingredients of my Audio. Making adjustments using solely Cans will get you a skewed sonic experience.
Patrick Tracy June 20th, 2019 10:24 AM
Headphones will tend to emphasize material panned to the side over material panned to center. This is due to the lack of cross bleed between left and right where the left ear hears some of the right speaker and the right ear hears some of the left speaker.
But it is good to check mixes on headphones since so many people do use them. If you have anything in the low frequency range panned to one side it can be uncomfortable to listen in headphones. The isolation between left and right is particularly unnatural at low frequencies since in real life anything below about 300Hz is heard about equally by both ears.
Graham Bernard June 20th, 2019 10:53 AM
Thanks Patrick. Excellent description of the usage and value of cans.
Adriano Moroni June 20th, 2019 11:08 AM
Important replies, I thank you. But someone could do video editing with the headphone and to adjust the sounds at the end. But maybe it is a double effort. ;)
Patrick Tracy June 20th, 2019 11:28 AM
I often to the actual video editing using headphones, but I definitely finish the audio on speakers.
Adriano Moroni June 20th, 2019 11:55 AM
Could I ask you which headphone are you using please?
Seth Bloombaum June 20th, 2019 12:55 PM
Sennheiser HD280
Graham Bernard June 20th, 2019 01:22 PM
Ditto Sennheiser HD280. Great close backs.
Pete Cofrancesco June 20th, 2019 01:42 PM
I use Sony MDR v6 which is a very popular and affordable choice.
I edit exclusively with headphones but I use my levels meter to judge volume. Just like I would use my wave form instead of my monitor to judge exposure. Everyones work is different but for me I’m listening for problems but I agree it’s good to listen to the final results on speakers.
I really like headphones because they isolate all the background noise I get at home, computer fan, ac window unit, leaf blowers, lawn mowers, you name it, there is a lot of background noise out there.
Adriano Moroni June 20th, 2019 03:31 PM
Hey, I have just bought a headphone but I think I made a wrong purchase because I bought a headphone with bluetooth. I think you need only need a cable and not a bluetooth in the video. I hope you can reply me as soon as possible so I can remove my order if it is wrong.
Patrick Tracy June 20th, 2019 06:52 PM
There's often too much delay in Bluetooth for me to use it when syncing audio to video.
