SHURE Lenshopper with Lumix GH5
I have a "SHURE Lenshopper VP83F" mike. Can someone please recommend some optimum settings, both for the mike and the GH5 when used in combination.
I'm interested in recording wildlife sounds over and above those I might get by simply using the GH5 internal mike. Ron |
Re: SHURE Lenshopper with Lumix GH5
Few (if any) wildlife sounds are recorded from an on-camera microphone. Typically the location that is optimal for the camera is too far away from what you are trying to record. Also, ambient wild sound is typically such low-level that very-low-noise microphones are favored by wildlife recordists.
There are several good videos on YouTube about wildlife sound recording where you can pick up some tips beyond equipment settings. I found dozens of them searching on: wildlife sound recording When you watch a nature video, the sounds you hear are almost never recorded at the same time as the video you are seeing. Here is a YT video I saw recently that shows "behind the scenes" of creating the sound track for nature video. |
Remember also there are no "magic settings" which work for everything all the time. You need to pick the appropriate approach for each recording.
Just like the camera dept gives thought to the right approach for each shot, as no shot is treated exactly the same. |
| All times are GMT -6. The time now is 02:12 PM. |
