-   -   Treating a room for voiceovers (https://www.dvinfo.net/forum/all-things-audio/530815-treating-room-voiceovers.html)
Marco Leavitt January 6th, 2016 10:34 AM
We need to treat a small, acoustically bright room for use in recording voiceovers. I'm thinking that the best, cheapest way to do it would be to get large acoustic panels and lay them against the walls. That way they could be moved out of the way as needed. The owner of the house doesn't want any holes drilled or anything, so something that is easy to set up and take down is required. The room has very old wood floors, so we are also planning to throw down the deepest, shaggiest carpet remnant we can find. I figure that should give us some help with foot noises and creaking boards as well as taming some of the room reflections.
Does this seem like a good way to go about this? Can anyone recommend what material to use for the acoustic panels as well as how to treat the edges, since I assume we are going to have to cut the panels into manageable widths and I want them to be easily carried without having fibers poking into people hands.
Thanks much to anyone who can help!
Marco Leavitt January 6th, 2016 10:49 AM
Picture of the room
Link deleted
Dmitri Zigany January 6th, 2016 11:00 AM
Re: Treating a room for voiceovers
Acoustic treatment is a rather complex affair. Different materials absorb different frequencies etc.
Depending on the size of the room you could get some of the thick fabric used on stages etc (molton?) and hang it on photo background stands. And combine that with the SE Reflexion Filter Pro or Space (don't use the cheap knock offs). That would be the easiest solution and also very easy to disassemble and even bring with you to other places...
Marco Leavitt January 6th, 2016 11:01 AM
Picture of the room
1 Attachment(s)
Here is a picture of the room
Jon Fairhurst January 6th, 2016 12:12 PM
Many pro voiceover booths are really tiny, which means that they need to be dead, dead, dead. They also need great isolation to remove outside sounds.
One approach is to use Corning 703 panels. They have great absorption, but only down to a given frequency. Corning 705 panels damp down to a lower frequency, but aren't as dead overall. 703 is just fiberglass while 705 includes a backing. You could stack them, if desired.
Hopefully, you are in a quiet environment so you don't need isolation. Just remember to turn off HVAC and other noise sources. Tell the family not to flush while recording. :)
One way to simplify things is to use reflective angles to your advantage. Let's say you put panels directly (and close) in front and behind you. For the sides, you could have solid surfaces at 45 degrees or so that bounce the sound out into the room. If the bounce back would hit an acoustic panel before hitting the mic, that's a win.
Then there is the floor. Note that recording studios tend to use wood, rather than carpet. That's because carpet kills highs but not mids or lows. Feel free to use a solid floor. Listeners are used to hearing that reflection. To compensate, put an absorptive "cloud" above you.
If you use fiberglass, make sure to cover it with cloth.
So, three absorptive surfaces (front, back, top) and two angled reflectors (left & right) would do nicely within a larger room - as long as you don't need to block outside sounds. Unless the talent has a really deep voice, four inch Corning 703 on a frame/board would be my choice. Door hinges would be one way to connect things. You can knock out the pins to take the whole thing apart and stack against a wall.
Oren Arieli January 6th, 2016 12:19 PM
1 Attachment(s)
The cheapest way to record would be in a walk-in closet filled with clothing. You can even record under a few heavy blankets from the comfort of your bed. Obviously, it's not as comfortable for long sessions, but it would cost nothing, and keep the house intact.
I created a portable v/o booth within a closet, but it was mostly for outsiders coming in to record. If you're the only one that will see it, then looks don't matter as much as acoustics of the space.
Robert Benda January 6th, 2016 12:52 PM
On the cheap side of things, I was going to say backdrop tripods strung with moving blankets from Lowes/Home Depot or quilts. That might not be enough for the room, but, for me, makes a lot of sense when I already own the things.
OTherwise, how does your guy feel about pillow forts?
Brian Drysdale January 6th, 2016 01:19 PM
We used to use cardboard egg trays mounted on the walls.
Greg Boston January 6th, 2016 01:53 PM
I did exactly that for recording narration on a national cable tv show. The closet is triangular in shape which is also helpful. Since I couldn't fully isolate outdoor noise, I recorded my sessions in the wee hours of the morning when there is no traffic noise, etc. Because I don't have AC power in the closet except for the overhead light, I recorded on a portable DC powered recorder. This eliminates 60 cycle hum and other power line noise issues. Although I could have used one of my condenser mics, I chose to use my Sure SM7 because it's dynamic so doesn't require phantom power and is less sensitive to far away sound.
Another decent recording environment is none other than the interior of your automobile.
-gb-
Richard Crowley January 6th, 2016 03:08 PM
You could make yourself a 2-side, floor-standing frame out of 2x2 lumber and hang that comforter/duvet (stolen off the bed) in a corner to make a temporary "booth". Put hinges where the two "walls" join, and it is easy to fold flat to store under the bed or against a wall, etc.
Roger Gunkel January 6th, 2016 03:34 PM
A very simple and cheap way to make an effective and easily useable voice over booth, is to construct an open fronted box, perhaps 30" square, lined with acoustic foam tiles or something such as a soft fur fabric. The box should be big enough for a mic on table mount tripod with a suspension mic clip, and big enough to lean into and be able to read your notes.
The box can even be made to fold up very easily for storage and re-use.
Roger
Don Palomaki January 6th, 2016 04:05 PM
And close mic. The closer the mic is to the speaker (within limits), the louder the voice it is relative to ambient sounds. And consider using a noise gate.
Speaking of in cars, take the car to an open field far away from people and roads on a calm day is a possibility. The main concerns would be wind, wildlife, and aircraft.
And don't over obsess if the rest of the audio has a relatively high noise floor. The room photo could be read to imply this is a modest budget project.
Chris Harding January 6th, 2016 11:25 PM
What really works is egg boxes ..we just bought a bunch of them from a packaging distributor and stuck them on the walls ... perfect!! However you can also make a portable booth like Roger suggests if you don't want to sleep in a dead room!! We had a storeroom under our garage so that was our permanent sound room ....even 3 sides of a booth will help a lot (leaving space so you can get inside !) Google portable sound booths and then make a DIY equivalent if you don't want to permanently convert a room!!
Andrew Smith January 7th, 2016 12:36 AM
You can also use an even *smaller* voice over booth. After all, it's the microphone that needs protecting from unwanted reflections more than anything else.
See The Original Voice Over "Porta-Booth"
Andrew
Richard Crowley January 7th, 2016 01:18 AM
Of course, none of those acoustic boxes (home-made or store-bought) can do anything about the room acoustics or the ambient noise. Their only function is to decouple near reflections (and perhaps noise) from the back-side microphone sensitivity. IMHO, they are over-hyped and not all that beneficial.
Roger Gunkel January 7th, 2016 05:28 AM
I don't think there is any suggestion that a box in a room is going to match commercial voice over facilities, but the OP wanted something that was simple and inexpensive to use in a domestic room. Assuming that kids aren't running around screaming, dogs barking in the room and Jumbo jets flying overhead, a reasonably acoustically insulated box with a close pop filtered directional or cardioid pattern mic will do the job well enough of damping out reflections and low level ambient noise.
Roger
Jonathan Levin January 7th, 2016 09:57 AM
+1 for what Richard and Roger suggest about ambient noise i.e. refrigerators cycling on and off, outside noise like sirens traffic and so on. How close are you to a busy street?
In looking at your photo and assuming you are REALLY doing this on the cheap, what i would do is make soe use out of that mattress/bed, maybe lean that against a wall and right there you have one third of a make shift sound booth. For the other sides, as has been mentioned moving blankets for Home Depot work well in a pinch. I use these a lot. Keep mic close to talent as has also been mentioned. Proper levels on everything, monitor your audio with some decent headphones, and test, test, test. Your ears will help guide you too.
Jon Fairhurst January 7th, 2016 01:05 PM
I've read some analysis about the small box-type solutions and they aren't all that effective. The main issue was the uneven frequency response. As is typical, HFs are easy; LFs are hard. On the cheap, blankets/duvets are the better solution, IMO. They also won't have a full frequency coverage, but they'll cover a larger area to help take the room out of it.
The frequency response issue is why I mentioned 703 and 705. Whether it's in-budget is up to the poster. It's generally cheaper than acoustic foam, so there's that.
Greg Allen February 4th, 2016 01:47 PM
Here is what I did. I purchased 3" rockwool from Lowes (Safe-n-Sound), made frames from 1x3's, covered them with my fabric of choice and stapled it on. I use this room to record professionally. Since I recently moved the room has gotten smaller similar to yours. It will be plenty "dead".
https://scontent.fsnc1-1.fna.fbcdn.n...73279024_o.jpg
https://scontent.fsnc1-1.fna.fbcdn.n...21615168_o.jpg
Rick Reineke February 5th, 2016 10:49 AM
Very nice Greg.
Renton Maclachlan February 14th, 2016 03:00 PM
1 Attachment(s)
For what it's worth, here is a photo of a voiceover box I've used for a project I'm working on. There is a Rode NT3 Mic in behind the pop filter. The box is made of 18mm customwood and lined with 'audio batts' and the box sits on the same to isolate it from the table...
The wall behind where the speaker sits is pretty dead...
