Quieter alternative to a Tascam DR-44WL?
I recently bought the Tascam DR-44WL and am very disappointed with the noise from the pre-amps when using a Sony ECM 55B lapel mic to record voices. Feeding the mic into a Sound Devices MixPre, and line level into the Tascam, improves things but only to an 'almost acceptable level'. Tascam says that there is not a problem with the recorder and that this amount of noise expected. Perhaps I'm hoping for too much from non-studio equipment but I wonder whether anyone has had a similar experience and found cleaner sound from an alternative in a similar price range - possibly a Mirantz PMD 661 MkII or Zoom 5 or 6? Feeding the same mic into an ancient Soundcraft Folio Spirit mixer coupled to a Sony DAT Walkman (neither 'top end') gives much a cleaner background that the Tascam, but unfortunately both are on their last legs now.
Re: Quieter alternative to a Tascam DR-44WL?
Assuming the recorder is set to (+4dB) line level via a good, properly wired XLR cable from the MixPre.. Did you calibrate the mixer>recorder with a test tone?
If you haven't done so already, remove the battery from the ECM-55's power supply and engage Phantom Power on the MixPre. "Perhaps I'm hoping for too much from non-studio equipment" > I'm not familiar with the DR-44, but I've used a 302> DR-40 combo and didn't experience noise issues.. though not specifically with a ECM-55 (which is a decent mic). I'll look at the Tascam DR-40/44 spec comparison for clues when I have time. |
| All times are GMT -6. The time now is 12:28 PM. |
