-   -   frequency scanner or ditch G2s? (https://www.dvinfo.net/forum/all-things-audio/521369-frequency-scanner-ditch-g2s.html)
Brian P. Reynolds February 9th, 2014 04:19 PM
Re: frequency scanner or ditch G2s?
The 'published' frequency lists most times are just a waste of time & effort, what you NEED to know is what is happening 'right now'............
A scanner is worth the money if you are going to use radio mics seriously..... It shows what is around and also the harmonics that are created by adding another TX frequency (yours)
Things like Taxi's,CB radio's, construction sites, 2 way radio systems & other radio mic users will be the main problem and none of those would be listed, they may not be in direct competition with your frequency but its the harmonics that are the problem.
Buy RF Explorer model WSUB1G [TES82252P] | Seeedstudio
Checking Frequency Compatibility
Josh Bass February 9th, 2014 10:19 PM
What tests would you recommend? I've gotten great reception when watching the RF meter/walking away from transmitter at HOME, through walls and 50-100 feet away (hard to measure), no dropouts. ON LOCATION, the last few times, horrible problems when the trans/receivr were only a few feet away. The obvious answer is "bad location", but I've had the unit for about 10 years and it's on recently that it's started doing that. The occasional "zzzzzt!" hit? Sure, dropout city? Recent phenomenon. Don't know what tests I could do that would help more than sending it in to Senn.
I guess the big thing I'm afraid of is that I buy the scanner, use it, it tells me a certain channel/frequency is open, I set the G2 there, and it still has problems. Then I'm out $129 for that scanner (unless they have a generous return policy).
Brian P. Reynolds February 9th, 2014 10:50 PM
Are you ever going to use a radio mics in the future? If you are then you will use the scanner again.
The RF spectrum is CONSTANTLY changing, it's not a fixed thing. Yes if you are a fixed location like a theatre or studio it may not change much but location shooting is a totally different thing.
Nicholas de Kock February 10th, 2014 12:34 PM
Josh out of interest which scanner are you looking at?
Paul R Johnson February 10th, 2014 05:28 PM
Let's say you are working at a location where you've had the problem. Clearly the cause is not a permanent thing - if it was, the scan function of the radios would probably have rejected it - so whatever is wiping you out, is not transmitting all the time, and don't forget that if the issue is de-sense, which makes the receiver appear to be deaf, then the scanner will not help very much, because it's not the channel you are using that you need to check, it's those very close. Hence why I'm suggesting a analyser and not a scanner.
I'm not sure how it is in the States, but many scanners do NOT have continuous coverage as your FCC has rules. I have receivers that cover our UK channels, but US frequency block A is missing from some of them.
Brian P. Reynolds February 10th, 2014 05:49 PM
2 Attachment(s)
Here are some screen shots of my RF Explorer.....
I would use it a couple of times a week for location shoots..
Simple, cheap and effective.
Josh Bass February 10th, 2014 06:17 PM
Im not sure i understand the last question addressed to me (which scanner are you looking at?)
Anyway, ive now gotten the opinion of two pro sound guys who say they trust their lectro scanners and therefore dont use a separate scanner. I dont know how it is with the 211, but the 411 displays the freq range as a bar graph the shows where the rf spikes are, giving you a way to find a sweet spot where little to nothing else is going on. That sounds identical to what the rf explorer does.
I work almost exclusively in houston and have only once in more than 10 years left texas for work.
Thinking a good plan might be a lectro 211 system, two ost lavs with hardwire adapters. Then i have not only a backup lav but the option to go wired when i can.
Brian P. Reynolds February 10th, 2014 06:32 PM
It comes down to $$$$$$ Yes some Lectro's have RF display features but they cost a LOT more than the Senni G2 /G3.
You can use a laptop with Senni software to get a GREAT real time display.
Yes you can use 'WinRadio' WiNRADiO Communications - The future of radio. as an analiser that uses hardware + software + Laptop PC.
I comes down to how much info do you want and how much do you want to spend?
Josh Bass February 11th, 2014 06:13 PM
Being that I'm pretty sure there's something wrong with the unit (even if there isn't--with its track record lately there's no way I can even remotely trust it now), maybe it's a "sign" that it's time to upgrade to a higher class of audio. I figure go Lectro rather than get another lower end Senn system (i.e. G3).
When you look at used prices on some Lectros, they are not horrendously more costly than a new G3, plus, you're getting what is objectively a better system.
Brian P. Reynolds February 11th, 2014 06:38 PM
If you are going to buy S/H be mindful of the frequency block changes that are happening world wide.... Don't buy a unit that will be in a banned block in your area..... It could be a costly mistake.
Rick Reineke February 12th, 2014 10:38 AM
The reports I've read from folks who attend the proposed FCC auction meetings agree the 600MHz block (TV channels 36-52) are likely the next to go. Not immediately.. but soon.
This just in: The auction previously slated for this year would be delayed until 2015.
Josh Bass February 12th, 2014 06:33 PM
Yes, thanks. I'm well aware of that issue. I believe it's block 26 in Lectro terms that's up for debate now. I have a few folks I trust to advise me on what's safe for the foreseeable future.
HOWEVER, with that said, people in town are still using stuff in the 700 band with no problems.
Anyway, if anyone's curious, Sennheiser will not simply examine my G2 without automatically fixing it, which means just to find out if there's anything wrong I would potentially pay basically what I paid for the unit to have it repaired, without wanting to. So I'm kind of stuck.
