-   -   Lav mic placement on a t-shirt (https://www.dvinfo.net/forum/all-things-audio/520027-lav-mic-placement-t-shirt.html)
Peter Berger November 14th, 2013 08:16 PM
Whats the best placement of a lav mic on a t-shirt?
Like this?
http://www.bz1-img.com/images_custom...65573_full.jpg
or lower?
Thanks for help!
Richard Crowley November 14th, 2013 09:40 PM
Re: Lav mic placement on a t-shirt
What does "best" mean?
Least visible?
Highest output?
Least susceptibility to background noise?
Easiest/fastest to rig and then remove?
"Best" for THAT microphone, or for some more high-end mic?
Brian P. Reynolds November 15th, 2013 02:35 AM
For a female clip the mic between the breasts between the bra and skin..(not between the bra and shirt)
For a male use some medical tape and stick it to the same position as per the female (between the breats at nipple line level)
Where you have the mic placed in the pic it would have changed the tonal quality of the mic.
Daniel Epstein November 15th, 2013 10:56 AM
Depending on the mic you are using and if you don't need to hide it you can turn the mic down onto the shirt instead of up to the mouth. Placing it so close as in the picture can give you too much presence. Brian's advice for hiding is good but not always easy if the person being interviewed isn't prepared for that level of intrusion. Reality shows which hide the mics often have control over wardrobe so other options can come into play.
Rick Reineke November 15th, 2013 11:32 AM
For quick set-ups, (hidden or not, inside or out) a 'vampire' pin clip is often used on the tee-shit collar. However this can sometimes sound muffled. Otherwise, I concur with the other posts.
