-   -   tascam dr40 or tascam dr 100 to use mostly with external very good mics (https://www.dvinfo.net/forum/all-things-audio/507335-tascam-dr40-tascam-dr-100-use-mostly-external-very-good-mics.html)
David Aliperti April 27th, 2012 03:12 PM
i need a small recorder to record mostly sound effects, i will use it with a couple of ms mkh40-mkh 30,
does anyone of you know tascam dr40 and tascam dr 100? what are real differences, about preampo and sound quality ?
Bill Bruner April 27th, 2012 11:21 PM
Re: tascam dr40 or tascam dr 100 to use mostly with external very good mics
David - Here is a pretty good comparison: http://dancarrphotography.com/blog/2...or-dslr-audio/
(Dan is wrong about the mic input levels on the DR40 - with the new firmware upgrade, they are now independent).
The bottom line is that the differences between the two recorders are all about features - sound quality is pretty much the same.
Summary of the differences:
The DR100 has separate headphone and line outs, the DR40 has a combination line/headphone out
The DR100 has a rechargeable li-ion battery pack, the DR40 uses AA batteries
The DR100 has 4 built in mics, the DR40 has two
The DR100 has more physical controls, the DR40 is more menu driven
The DR40 has only two real advantages over the DR100:
The DR40 has two 1/4" TRS/XLR combination inputs, while the DR100 has XLR-only inputs, and
Lower cost.
I wanted the 's separate headphone and line outs, but for me, the most compelling argument was cost, so I bought the DR40.
I have been more than satisified with its performance.
Good luck with your decision,
Bill
Hybrid Camera Revolution
David Aliperti April 28th, 2012 02:45 AM
considering that I need it to record sound effects with external pair of microphones in a boom, i just care about phantom, good preamps and how long battery life is. there's no lithium battery inside the dr 40 thats may be a problem.
Rick Reineke April 28th, 2012 08:31 AM
Neither the DR-40 or 100 has very good pre-amps, but in this price range, the Tascams' are as about as good as your gonna get. For recording quiet sound sources, noise may be an issue. Using a quality high output level mic would help minimize the noise.
