using 2 microphones on the mzs 20-1 pistol grip
I have a mkh416 on a sennheiser pistol grip mzs 20, i need to put in same wind shield kit, so on mzs 20 a mkh 30 with the 416,
i was wondering if i have to purchase a new suspension or can i find just some spare parts to fix two microphones. thanks |
Re: using 2 microphones on the mzs 20-1 pistol grip
But it was not ideal as the basket was too small in diameter and the upper mic. was too near the edge. If you want to do it like this, then you will need a pair of the new back-to-back clips from Rycote (these will hold any diameter from 19mm to 25mm including the square-sided MKH 30). These are the only clips that will work. But this is not really good. It's best to get a Rycote stereo windshield and ConnBox designed for the task. Rycote's new design for the suspension was a suggestion put to them by me when I decided to replace the horrible rubber O-rings with the much better Lyre suspensions. I modified my own one and Rycote liked it so much they started using it as their standard design. The bonus is that it's quite a bit cheaper than the hoops and rubber O-rings. |
how do i fix the MZD 30 on mzs 20, or can I get 2 back to back rycote clips and fix them on mzs 20, ill use mkh 416 or mkh 30 or both when i need ?
But the 416 is only 19mm diameter, so it won't work. With this combination you need the two Rycote back-to-back clips which fit both the 19mm MKH 40 and the 25mm square-sided MKH 30. |
yes, i bought the he two Rycote back-to-back clips, but anyay ill buy a rycote Stereo WS Kit AG kit, but their site is confusing, they don't have a detailed description of single item, i need one STEREO kit that fits vp88, mkh416/mkh30 , mkh40/30
The WS Kit AG (080201) should suit both stereo combination MKH 416 / MKH30 - MKH 30/40 - though the suspension might be a little stiff for the MKH30/40 combination, as it is much lighter than the 416, for which Rycote recommend stiffer Lyres to support the weight. The Shure VP88 needs a slightly different suspension, as it requires 30mm grey Lyres on risers (so it is centred in the basket) - instead of the 19/25 mm Lyres fitted to support the MKH 416 and MKH 30. The alternative option would be to purchase the WS Kit AG, together with a Lyre cradle upgrade and some risers so you can adjust the height of your mics inside the basket). This Lyre cradle is very similar to a Softie Lyre mount and would be able to support any of the mics. Large Mic Cradle Upgrade: 040121 1 X set of 20mm Stereo risers WS Kit AG: 080201 However, as the lyres for the 416/30 combination are stiffer than for the 30/40, I would add to this list the correct lyres for the 30/40 as well. I hope this answers you OK. |
| All times are GMT -6. The time now is 11:20 PM. |
