PCI Audio Interface Card Advice
Getting close to a new audio interface purchase for editing computer. Would like user comments and feedback on which of the following PC interfaces might be best for audio for video editing and mixing.
Notes on the context: Will be doing limited live recording at present and when I do an external mixer with preamps will be added for input so having on-card mic preamps is not a factor one way or the other. May however be recording analog or digital audio to capture from location sound recorded double system or production music recordings etc. Want to be able to edit, mix and sweeten music, SFX, dialog, general sound design etc properly. Mixing to stereo and 5.1, delivery mostly on DV, DVD, and probably some VHS. Audio software under consideration includes Audition, Acid, Soundforge, Audacity, Vegas, and/or Nuendo (have seen some recent discussion about Traktion that sounds interesting for recording so will be looking at it as well) - am really starting to like the looks of Nuendo but holding off on final software decisions until I've had chance for a bit more hands on with them so this post is hardware rather than software related. Using a Contour shuttle at the moment and planning on a Mackie Control for the user interface as soon as the budget permits. Analog video I/O and capture of digital video sources probably with a Canopus AVC110, 300, or ACEDVio and of course also direct Firewire from the camera. So when it comes down to the soundcard to go with all this ... Considering only PCI card interfaces for the moment and narrowing it down to the following options, what are people's reactions to and opinions one way or the other on ... Delta 1010 Echo Layala MOTU 2408 Emu 1820m and just to be fair SB Audigy 4 Pro SB Audigy 2 ZX Guess I'm trying to say I want to set up a class "A" audio-for-video mixing and editing suite but not a music recording or MIDI composing studio. If you could take your pick for a Windows-based DAW with very limited live studio recording but strong multi-channel mixing and sound design requirements and using the above mentioned software/hardware, which would you choose and why? I'm pretty sure I already understand the answer to this one but tossing another question out to the group to make sure I haven't overlooked anything, how does the number of channels in the sound card effect the number of tracks one can work with in the editor at any one time, or does it? As far as recording from the inputs, it's obvious that if the card has 8 input channels, there can only be a max of 8 separate tracks being recorded at once but on the output side, if there are 8 output channels does that mean you can mix an unlimited number of tracks into a maximum of up to 8 output streams or does it mean you only work mixing 8 tracks on the timeline at a time? Again, obviously if you use some hardware signal processing during the mix - external hardware compressors and equalizers for example - each one you use will require a pair of I/O ports for its sends and returns but for the moment lets say all processing will be done strictly in software. In that case does the number of output channels on the card only affect monitoring and final analog I/O or does it also limit the number of tracks that can be worked with any one time in the editing software? If we were working with an unspecified number of multiple files that were already on the computer in WAV format, mixing them down into multiple tracks and ultimately rendering the mix back to saved WAV format or AC3 files on the PC with no external hardware processing or analog output required, and were willing to work deaf with regard to monitoring, would we even need an audio interface in the system at all or could we do it all with software on an otherwise basic PC? |
Hi Steve,
I can't say anything but good things about the Delta 1010LT. I needed an audio monitoring upgrade and MIDI in/out for my Mackie Control and it fit the bill. As for monitoring, each piece of software might it a bit differently and you may want to make sure that whatever you use supports the audio solution considered. I use Vegas and ASIO drivers, regularly monitor full surround mixes. Every audio track is assigned to a bus, and these busses are routed to the sound card outs. So technically, you can have as many audio tracks as the software is capable assigned to one or more channels. I've heard good things about the Echo Layla as well, but cannot personally vouch for it. I've also heard that Audigy cards should be avoided in an application like this; the DACs are not quite up to snuff. Cheers, -Matt |
Wow! Quite a broad range there.
I'd highly recommend the Echo Layla, the M-Audio Delta 1010 as I have both. In the PC world, I can't recommend the MOTU, but in the Mac world, they are super sweet. (driver issues, not hardware issues, and their PC tech support stinks) The Emu is too new to know, but know that Emu is part of Creative. As far as the Audigy well...if I were on a deserted island and had no internet/UPS delivery and found one on the beach....I'd use it. Otherwise, not a chance. Lots of coloration, poor DACs, lots of noise...a very nice looking consumer interface with driver issues. |
Your prioritizing was pretty much what I was already thinking and only listed the Audigys in order to give them a fair chance. Have been most favouring the Delta and Layla cards, recently leaning mostly towards the Layla. When or if the need arises, for live recording mixing at the analog source level have been thinking of a Mackie Onyx perhaps with its internal firewire interface card when the need begins to justify the cost. |
FWIW, the converters that drive the Onyx are the same converters that drive the Layla, I believe. Echo Audio developed the hardware/software for the Onyx series boards for Mackie. You'd be happy with either. Keep in mind that with the Mackie, you don't have multiple outputs, just stereo over firewire.
That's correct. But not over firewire, unlessyou buy the firewire kit.
http://www.mackie.com/products/onyxfirewire/ I probably should have been more clear about that. Sometimes I'm too quick on the "submit" button. :-) Additionally, you can only monitor a stereo mix from the computer. In other words, if you're expecting the Onyx, which is a very fine console, to act as an I/O card like a Delta or Echo Layla, it won't. It's a different animal, not designed to work this way. |
As you already know, the Audigy probably don't belong in the same category with the others. I can't remember if it's the same for the Audigy 4, but I've read several times that the Audigy 2 resamples everything to some set rate internally (48kHz maybe?) and then back to whatever sample rate you have set, which seems a little crazy if it's true. Also, do the Audigy cards have ASIO drivers? You'll want ASIO for any serious recording in Cubase or whatever recording program you'll be using. Maybe the Audigy cards come with them, but I'm not sure. In any case, Audigy cards are more geared toward gamers.
Based on what I've read, the 1820M A/D converters are the best of the group in your list, but their drivers can be spotty for some users. Meanwhile, the Echo Layla gets high marks all around, and the M-Audio Delta cards are uniformly praised for rock solid, low latency drivers. If I were in your shoes, I think I'd pick the Layla, followed by the 1010LT, then the 1820M. RME's Fireface 800 is another new card getting good reviews for great sound and good drivers, although it's about twice the cost of the ones you've listed. |
I've only got the Audigy 1, but it even came with a limited version of Cubase. It may not be in the same league as a Motu, but it does what it is supposed to. The breakout box is the best thing I ever got, as I can jack in through the front now.
| All times are GMT -6. The time now is 08:29 AM. |
