Recommend a mini-portable audio recorder?
Any recommendations for a mini-portable audio recorder? I was thinking of picking up a couple of Zoom H1s for a documentary but then noticed this part of the market has really exploded.
Tascam DR-03 Tascam DR-07 Tascam DR-08 Tascam PR-10 Zoom H1 Zoom H2 Alesis PalmTrack |
I have the DR 07, and own a and H1 that I just bought, and had to send back because of a battery drain problem. It seems the early models of the H1 had some drain issues, though they record fine.
I use both as a recorder for my Sign Video ENG 44 mixer, and they both work great for that purpose. The H1 has a very simple record interface, and slider switches to choose various setting. The DR 07 gives more recording choices, and you need to access menu. I haven't used either extensively standing alone using their on board mics. My brief experience with that type of recording favors the H1, but as I said, I did not test against each other, and can't support that with anything but limited trial in similar situations. Build wise, I think the DR-o7 presents a much more solid, but heavier piece of equipment. |
Sony PCM D50
Jim the Sony PCM D50 is really nice but it's around US$500. The others recorders I mentioned are around US$100, the idea being to get a handful of inexpensive mini recorders and stick them close to the subjects. I already have a sound guy with a full kit, but he can only do so much, so we're going to add several US$100 mini-recorders for better flexibility and coverage.
Got it! I guess when you said a "couple" you were meaning a "bunch"!
Most of these small recorders work well as long as you DO NOT USE the built-in mics, thus you have to add the cost of a lav for each person you want to record.
My preference is for the Olympus LS-10/11 or Sony PCM-M10, both record very good audio and will run for almost two days on 2 AA batteries. If price is an issue, then the Zoom H1 + Lav might be the cheapest way to go. |
I use the H1, H4n and Olympus LS-10. All of them will give you great quality audio, but the feature set differs. If you even think of using a pro quality (XLR) microphone, then the H4n is a good bet. The H1 has a smaller display that makes it harder to monitor, and chews through AA batteries at an alarming rate. Build quality isn't the best either, so keep it well protected. The LS-10 is a solid chunk of recorder with a much better battery life, easier to read display and tactile controls that make it a little friendlier to use. I've had more audio drift with the LS-10, which is the only reason I use it less often than the others. I don't think any of these units will keep perfect sync over long interviews, so take my advice with a grain of salt.
I use the Olympus LS-10 for long-form live events without any problems, but I always adjust the sync on the WAV files afterwards using the cheapest audio editor I own ( GoldWave $19 to buy ) because it has a very accurate time adjustment feature called TimeWarp ( good to 0.0001 seconds when processing hours of audio ). Depending on the camera I am shooting with, the sync has to be adjusted for between 2-20 frames of drift every hour recorded. I can completely adjust an hour of audio in less than 1 minute, so it`s a pretty quick process. |
Those Zoom H1 recorders look cool for what they are, and they will power the new Rode Lavs when you get the MiCon-2 connector.
| All times are GMT -6. The time now is 11:30 PM. |
