Z5 XLR and internal mic
Hi everybody,
I'm looking to purchase a wireless system for Sony Z5. I'm debating between 1 or 2 receivers. If I were to plug both receivers into inputs 1 and 2 will the internal mic be disabled or still act as shotgun type mic to pic up surrounding sounds? Thx for any advice Melvin |
On the Z5 you set a switch to choose between XLR inputs or internal mic for each input. But choose you must.
In most instances you can't have multiple sources going to a single channel without an external mixer.
I'm debating between 1 or 2 receivers.... and only one transmitter? If you would like the audio going to both channels, a 'Y' cable would be somewhat cheaper. A single transmitter / two receiver set-up can be useful in feeding the same transmitter source to two separate cameras. (However that does not work the other way around. Two transmitters / One receiver) |
| All times are GMT -6. The time now is 09:51 PM. |
