702 out into camera
Hi, does anyone see any benefit going out of the 702 and into the camera. Not just for a guide track,
Anyone actually used the audio going out of it and recorded into the camera and then using the camera's recorded audio, any benefits, experiences with this please? |
Sounds like you're wanting to use your 702 as a mixer?
One advantage will be the 702's limiters. Other than that, if you're recording single-system then a mixer would likely have many more advantages.
Something like Pluraleyes could automatically sync the 702 audio with the camera audio in post (I've yet to use it on a real job, I'm slightly skeptical but it does seem like it's relatively successful). Using double-system would give you more flexibility and likely sound much better. |
Provided you're sure you only need two channels, that you have the right TA-XLR cables, and that you bypass the camera's own preamps (usually craptastic), then sure. I've done this very thing with no issues. A MixPre or 302 mixer would be cheaper and a lot lighter, but if you already own a 702 and pretty much just want to use its limiters and preamps, yeah, it's a snap.
thats exactly what i was looking for. And of course we're bypassing the camera's pre-amps using line level. I already own the 702 and i thought it can serve a multi purpose mixer and recorder. I can use it as a mixer in this case and a recorder when i need to collect SFX, ambience, song recordings etc. I will give this a shot once i order the cables. Thanks.
BTW, im guessing the camera's limiters would be off when going line in. |
Does the HVX200A do this too?
