Looking for Boom Stand Case recommendations at DVinfo.net
All Things Audio
Old November 17th, 2009, 07:38 PM   #1
What is an inexpensive case that can be used to transport a boom stand or more than one boom stand around town that will fit a 46" long boom stand (when closed - specifically the On-Stage SB9600 and the Manfrotto 420b)?
Michael
Michael LaHatte is offline   Reply With Quote
Old November 17th, 2009, 08:04 PM   #2
inexpensive makes it tricky. You can get On-Stage mike stand cases from such places as Musiciansfriend.com and americanmusical.com. The Manfrotto, harder; try bhphotovideo and search tripod cases, they have a number by various manufacturers, but not what I would call cheap, ymmv. /Battle Vaughan
Old November 17th, 2009, 08:53 PM   #3
I found this one: Kata | LS-54 Light Stand Bag | KT LS-54 | B&H Photo Video .. it seems nice.. will fit 4 up to 54" ...
Old November 17th, 2009, 08:59 PM   #4
for an unpadded case that will accomodate a few stands, check out the golf guard travel case for a golf bag on amazon, or at your local sporting goods store.
You can put everything you mention in it, as well as your tripod soft case, and a few lights.
A friend uses this as his travel tripod case - works well.
SB
Old November 18th, 2009, 03:00 AM   #5
I'll second Seth's suggestion.
I got a golf case from Sports Authority for $100 and it's been working fine for a few years now... But the handle did break off, which I repaired with fiberglass and epoxy. And a small hole got punched into the bottom which I also fixed with fiberglass and epoxy. All the damage was done by airline travel, which is to be expected.
Here's the case I got. They're probably available from various sources:
http://www.digitalgiftstore.com/9735-1.html
Dean Sensui
Old November 18th, 2009, 05:43 AM   #6
What do you use on the inside of that golf case to protect the stands from scratching each other?
Old November 19th, 2009, 06:02 AM   #7
There's nothing to keep the stands from scratching each other.
If you really wanted to keep the stands pristine you can wrap each one in a towel. For me, cosmetics is unimportant. As long as they don't get damaged and operate smoothly, I'm OK with it.
Dean Sensui
Dean Sensui is offline   Reply
