-   -   bwf poly files, in logic or final cut (https://www.dvinfo.net/forum/all-things-audio/465151-bwf-poly-files-logic-final-cut.html)
David Aliperti October 6th, 2009 02:44 AM
hi i am recording 4 tracks in a bwf poly files, i am new on mac and logic and i am just experiencing that logic does not displayu poly files as nuendo does. so i had to open it in final cut but cant work on it as need, any suggestion?
Wayne Brissette October 6th, 2009 04:23 AM
David:
You'll need to make them mono files. This is one of my peeves against a lot of the DAW software (on both Windows and Mac OS), they simply don't handle these type of files correctly. To split your file, download Fostex's free BWF Manager or Sound Device's Wave Agent.
BWF Manager Software - Broadcast, Film and Pro Audio
Wave Agent | Sound Devices, LLC
This will allow you to expand the poly file into mono files for each channel. Then you can take those mono files and import them into your DAW.
Good Luck.
Wayne
David Aliperti October 6th, 2009 05:23 AM
i wonder if editor who i am sending material will be able to handle them, he uses AVID
Jeffery Magat October 6th, 2009 07:20 AM
If I remember, its only the old AVID systems that need them in mono.
Zack Allen October 6th, 2009 09:54 PM
Or don't record in poly.
Dean Sensui October 8th, 2009 01:22 PM
I'm using FCS v 6.0.5 and the multi-track BWF files work just fine. What sort of difficulties are you experiencing?
