MK41 on a boompole
Dumb question, but how exactly do you put an MK41 on a boompole? All the pictures I've found suggest I would need something else as well (images in links below)
http://www.hhb.co.uk/hhb/uk/products/detail.asp?ID=943 http://www.dv247.com/invt/20942 EDIT: Hmm, after further searching, it seems I'll need a CMC-6 amplifier as well. |
And a shockmount and some wind protection.
Steve there isa body that goes with that capsule as well. You are looking at pics of the capsule alone and with the optional powered cable. Not sure what the model # is but with the capsule attached to the body you will be able to connect to a shockmount/boom pole.
: oops didnt see your edit but yes thats what you need. maybe one too many newcastles tonight than i should of had.... |
| All times are GMT -6. The time now is 05:27 PM. |
