-   -   XLR Adpater & Settings (https://www.dvinfo.net/forum/all-things-audio/38529-xlr-adpater-settings.html)
Gareth Watkins January 29th, 2005 11:44 AM
I have a question regarding the best settings for use with an XLR adapter with the camera....
I have a Sign Video XLR PRO plugged into my camera... I've always set the camera to manual at max volume and used the volume controls on the adapter to set the mic input... just wondering if this is the best way of doing it...
What do others do to get the best possible audio?
Regards
Gareth
David Ennis January 29th, 2005 07:38 PM
Personally, I have an aversion for cranking anything full open, but that's just me. Other than that, your approach makes sense to me, assuming that your cam has level meters...certainly assures that the input to the camera is not too strong.
I use a BeachTek DXA-8, which has preamps and limiters, with my GL2 so my procedure is a little different.
First I ensure a proper level to the Beachtek, which is only a concern when I take a line from a sound board or use a very hot mic like an AT4073 (which I don't have). The DXA-8 is designed for mics only, so it's up to me to attenuate the signal properly. I use an AT8202 in line attenuator, which is switchable between -10, -20 and -30dB, at the BeachTek end.
Next I turn on mic attenuation in the GL2, which is a menu option. With MIC ATT on, the nominal input (or the maximum--the Canon manual doesn't say which it is, and they don't answer my email) is -35dB. The Beach can't put out more than -38dB, so the GL2's input is protected from overload.
Next I turn up the Beach's gain until its limiter indicators flash frequently. This tells me I have the optimal signal to noise ratio in what's being fed to the GL2.
Finally, it's just a matter of turning the GL2's level controls up until the meters peak comfortably below 0dB. On the GL2, an occasional amber colored meter segment indicates the peaks are hitting just above -12dB.
Jay Massengill January 31st, 2005 09:08 AM
On a passive adapter like in the original post, I would run the adapter at maximum (or perhaps just 1 notch down) and set the camera's manual controls for an optimum recording level. I think that will give you better noise performance.
