-   -   AT822/AT825 question (https://www.dvinfo.net/forum/all-things-audio/38477-at822-at825-question.html)
Francois Poitras January 28th, 2005 01:26 PM
Hello Everyone,
I am looking for a reasonable quality stereo microphone to mount on my PV-GS400 for general indoor/outdoor ambiance recording. (I already have a Sennheiser K3U/ME80 shotgun for mono situations.)
I am not ready to purchase an audio adapter with phantom power and I would prefer a lighter, battery operated mic. So after a bit of reading on the subject, it comes down to the AT822 or AT825 (I think I would have gone with the Rode NT4 if it had not been so heavy).
The AT822 seems to be a good fit: I heard good things about it, it is a light mic, it has an unbalanced output for the cam’s minijack and the price fits my budget. However, I might be tempted to go with the slightly heavier AT825 because of its balanced output, in case I decide to go for an audio adaptor in the future.
My first question is about the cable to be used with the AT825. I already have an XLR 3-pin to stereo miniplug for my ME80, which I made myself (works well). Would there be a problem with a similar XLR 5-pin to stereo miniplug cable for the AT825? I can’t seem to find such a cable on the Hosa site.
And finally, I am looking for audio samples of the AT825 or AT822. I found a few on the Web, but these were for loud music recording. Would anyone know of a sample recorded in quieter situations?
Thanks in advance!
François
Francois Poitras January 28th, 2005 08:12 PM
I guess I should indicate how I would wire the cable.
According to the Audio Technica AT825 documentation, the XLR pins go like this:
1 - shield
2 - left (hot)
3 - left
4 - right (hot)
5 - right
So based on this:
http://www.hosatech.com/hosa/products/yxf-247_and_yxf-305.html
I would wire pins 1-3-5 to sleeve, pin 2 to tip and pin 4 to ring.
Does that make sense?
Jacques Mersereau January 29th, 2005 10:16 AM
1 - shield
2 - left (hot)
3 - left
4 - right (hot)
5 - right
So based on this:
Yup. That should work.
Francois Poitras January 29th, 2005 10:35 AM
OK thanks, Jacques. It is simple stuff, but I just needed a confirmation.
Still looking for AT825/AT822 samples recorded in (relatively) quiet environments...
François
Gints Klimanis September 26th, 2005 11:31 PM
I have the Panasonic GS250 as well as the AT822 for my Sony VX2000, though I've never tried the mic on my new GS250. It's a sweet microphone, but it's pretty much as big and heavy as the camera.
Gints Klimanis September 26th, 2005 11:33 PM
I just read the on-line technical info for the AT822 at BH Photo. Apparently, phantom power will damage this microphone.
" Power Requirements Battery AA (1.5v) WARNING: The AT822 is designed for battery use only. Do not attempt to use when phantom power is present. Possible damage to the microphone could result! "
http://www.bhphotovideo.com/bnh/cont...ughType=search
Francois Poitras September 27th, 2005 06:40 AM
Gints, thanks for the info. That was a while back and I got the AT822 since then. Yes, the microphone documentation clearly states that phantom power can damage this mic.
And you’re right, it is a sweet microphone.
