-   -   Wireless Receiver using Powered-XLR? (https://www.dvinfo.net/forum/all-things-audio/20625-wireless-receiver-using-powered-xlr.html)
Law Tyler January 30th, 2004 12:46 PM
Well, got one of those dedicated 9v battery charger, seems to work good, charges in two hours, up to 10 at a time. I tried 4 at a time so far, works.
My Samson UHF Micro32 diversity receiver use one up in two hours (the transmitter longer, closer to 4 hours), perhaps because the receiver actually has two receiving units?
But it just occured to me that since they are used primary thru the XLR connector, why don't they make it use the XLR 48v power? Voltage a little high, but I am sure they could step it down.
Does any other small receivers out there use the XLR power?
Is the XLR power constant at 48v or does it vary with the situation?
Had a receiver went out on me during one event, unlike the small Airline Micro series which uses a single AAA, but last 8+ hours. Of course the output is pitiful, which is why I typically don't use it.
Nice to have a receiver with power that does not go out, unless of course the camera runs out of battery also.
Marty Wein January 30th, 2004 01:30 PM
I see in your profile that you use the Sony DSR-250. If true, you can use the Lectrosonics PS-12 cable (or the PS-212 for two receivers) to power the receiver through the 4 pin HIROSE power output located at the back of the camera.
http://www.bhphotovideo.com/bnh/cont...=212167&is=REG
http://www.bhphotovideo.com/bnh/cont...=283248&is=REG
If however you are not using this camera, but you have a seperate battery pack like a vest or belt for lighting etc. and it uses either a 4 pin XLR or a Cigarette Lighter connector you can use the NRG cable.
http://www.bhphotovideo.com/bnh/cont...u=66897&is=REG
http://www.bhphotovideo.com/bnh/cont...u=66898&is=REG
BTW: The above is also true for the Lectro and Audio Technica 100 ser receivers
Law Tyler January 30th, 2004 01:42 PM
Hey, thanks.
I wonder if the cable steps the voltage down to 9v or 12v. The Samson manual said the DC-in is 6v to 13v. Does not look like it has any kind of circuit.
Guess I can use an XLR splitter to use the audio-input as well as the power from the same outlet.
Samson also said in the manual the NiMH is supposed to last 8 hours for the receiver, I guess that is why it does not even try to use the XLR power. Problem is that in reality, it last only TWO hours.
Those lying cheating #@(*$#@(*$...
Marty Wein January 30th, 2004 01:49 PM
The cable does not step it up or down. The output of the camera is 12v. This is how all pros are doing it.
The Samson reciever will work fine with any DC in as long as it is not above 13v or below 6v.
I am not so shure about the XLR splitting....
Law Tyler January 30th, 2004 01:56 PM
Thanks again.
Kind of funny, because on my DSR-250, the XLR power is said to be +48v. The 3 settings are "line-in", "mic-in", and "mic-in plus 48v power".
There is a single 12v output at the back, but it has some kind of funky looking four-pin-in-square-arrangement type connector.
There is also a 4-pint XLR-looking 12v input into the camera.
Marty Wein January 30th, 2004 02:45 PM
The Funky Looking connector is the 4-pin Hirose I mentioned before and to use that, you will need the Lectrosonics PS-12.
I would check with somebody who is more technical about the +48v on the XLR's. I don't think it will work.
For $35 I would go for something that will work, instead of messing around with a custom cable that will either not work or worse, ruin your receiver.
Marty Wein January 30th, 2004 02:49 PM
BTW: Check out the link below where you will learn a bit more about +48v Phantom Power.
http://www.tangible-technology.com/p...r_connect.html
Law Tyler January 30th, 2004 04:04 PM
THANKS!
I read your original post too fast.
