quick mke 300 question
i just recieved my mke 300 today. i replaced the battery in it and tried to turn it on but the red LED only flashed. tried a different battery and still the same. does it have to be MOUNTED onto the camera for it to turn on or the audio jack has to be plugged into the camera? or did i recieve a broken mke300
Did you try the mic after turning it on? Thats how the light is on the Senn. ME66 so Im sure its the same for the MKE and that the mic is properly working.
S'OK
like mike says...
its ok or at the least it works just like mine, a blink and then no steady light but mine works just plug it into your cam and compare to the onboard, and dont throw away those batteries!!
m |
Just got mine a couple days ago, mine does the same flash thing and blows away my onboard mic.
This is absolutely normal operation. (See the pamphlet included with the mic.) The light should only wink once when powering-up. This indicates that the battery has power. No wink, dead mic.
| All times are GMT -6. The time now is 01:49 PM. |
