HF10 + Shure SM58 + Shure A96F
For now I just have the HF10 and a Shure SM58 microphone, and a cable XLR female, to connect the SM58, to 3.5mm plug.
When I plug de SM58 directly in the camcorder I have to put the maximum amount of recording volume to get a good volume of audio, but then the noise is also very high. This is because the cable right? My question is: if I buy a Shure A96F I remove the noise right? But the volume of the microphone will be good? I will use this camcorder in two ways: first, do external interviews. second, record the events that happen in my church. At church I use an auxiliary output from the mixer to turn the sound on camera. I need to know if the SM58 works well to do external interviews and and if I buy the Shure A96F it will solve my problems. I apologize for my English |
The SM58 is best suited for live performance stand or H/H vocal with a medium-high SPL source. It's low output level does not work well as a camera mic, It could be used as a H/H interview mic however, but it's not really designed for that application.
ok..
what microphone with a high output I suggest to you do interviews? and what would be a preamplifier, the BeatchTek is one? |
A standard reporter's interview mic would be the ElectroVoice RE50 or 635. Another good choice is the Sennheiser MD46 |
<i>A standard reporter's interview mic would be the ElectroVoice RE50 or 635. Another good choice is the Sennheiser MD46,</i>
The EV RE50 N/Dym has a little higher output.. but in your situation, I would look to an aforementioned pre-amp before purchasing another mic. With a decent mic-pre, your 58 would probably work ok for TV-reporter type interviews. Sorry I'm not familiar with your camera. I gather there are no balanced mic inputs. (XLR) |
