-   -   Edirol r4 pro bleeding? (https://www.dvinfo.net/forum/all-things-audio/135174-edirol-r4-pro-bleeding.html)
Chris Sweet October 3rd, 2008 03:13 PM
So my recorder sometimes now spits audio into my right headphone (for a few seconds at a time when it happens) when I'm recording Ch1 alone (left)
However, I do not see the right meter move at all on my screen. any ideas what this could be and how I could fix this?
Steve Oakley October 3rd, 2008 11:59 PM
busted headphone jack on editrol unit, maybe something in the jack itself,
busted headphone plug or wiring - take it apart and see if there is a stray loose wire. it happens.
Robert Gordon February 27th, 2010 09:26 AM
I just found this thread a bit late doing a search, but my R4 Pro sends an identical signal from mic 1 to both channels 1 and 2 (the front panel meters and both sides of the the headphones) - but it records to track 1 properly. Mic 2 does not register on the front panel meter at all though it too comes through both sides of the headphones (yes I do have the monitoring option set to 1L, 2R) - but it's recording seems mixed with channel 1. Mic 3 registers on meter 3 and comes through the left headphone just fine. Mic 4 registers on meter 4 and comes through the right side of the headphones, but does not record! So my unit appears to be brain-damaged.
I've contacted Roland via their website two weeks ago and thus far received no response. Usually they respond quickly - at least when the problem is a user error!
Chris Sweet March 16th, 2010 02:14 PM
thanks Steve
exactly what the prob was
