Dual coldshoe adapter (for shotgun and wireless)?
I need to mount a shockmount (for my AT822) plus a G-100 wireless transmitter on my FX7.
A simple dual cold-shoe adapter could be a solution, but the most suitable one I've found so far got dinged on the review for being plastic - plus the spacing between shoes may be too tight: http://www.bhphotovideo.com/c/produc...Accessory.html Any alternative suggestions? Thanks in advance. |
What about this one?
http://www.bhphotovideo.com/c/produc...and_Sound.html I haven't used it personally but it looks nice. Maybe too tall though if you really wanted a flat one. |
Thanks for the suggestion!
Not sure about the extra height though ... I use the camera in the field and a lower profile might be preferable. |
I use this one:
http://www.bhphotovideo.com/c/produc..._Bracket_.html Very useful as long as you don't mind the incredibly strong smell of rubber from it. It goes into the tripod fitting so it might not be suitable though. |
Hmmm ... I saw that one but figured it would block the FX7's LCD, which opens out by about 4". Thanks though.
Grahm, I have used both of the brackets shown. The PAG is a good idea, but the shoes will be too close. The Cool Lux one, is well built, but I don't likt the high profile of it and I got too much handling noise from it.
Now here's one by Frezzi. While it is expensive, it seems to be well built, low profile and large enough for 2 wireless if needed, so a shotgun mic an wireless will be easy on it. http://www.bhphotovideo.com/c/produc...mera_Shoe.html Also there's this from VFGadgets http://www.vfgadgets.com/EXT-AK04.htm The VFGadgets stuff BTW is very well built, as I have a handle bracket from them. |
What about the Rycote 037303 Hot Shoe Extension Bar???
http://www.bhphotovideo.com/c/produc...Extension.html |
Or even better, here's a longer version of the same bracket. http://www.adorama.com/RY037701.html This will give you more area to mount 3 accessories if you like, like this... http://www.s131567196.onlinehome.us/...adcast_06b.jpg |
Thanks guys - I'll try the Rycote as a starter - some of those others look good for a light, which maybecome a factor soon as well, so good info to have.
| All times are GMT -6. The time now is 11:46 PM. |
